oil pump, timming chain, pully,cam, springs fs!!!
8 second mod
i have a new GM LS6 oil pump for sale never used. $100
New never used roll master timming chain $100 ---sold
new never used under drive pully forget which one i think slp will confirm $125--sold
used valve springs with retainers, dual springs from my afr heads. used 1 season with a 232 580 cam still good pressures with titanium retainers $125---sold
cam for sale also, used 1 season
custom grind comp
23x/23x 57x/57x @ 112 $225
all prices are plus shipping.
custom grind comp
It Is Just The Chain Or It Comes With The SPROCKETS? It Is Double Roller? Will Fit My 98 Ss Camaro Ls1? HARMONIC BALANCER AND UNDERDRIVE PULLEYS IS THE SAME? CHECK IF IT IS FROM SLP? WOULD BE INTERESTED IN BOTH AFTER GET SOME ANSWER TO MY QUESTIONS. THANKS.
DO YOU ACCEPT PAY PAL?
8 second mod
Rollmaster
Rollmaster Double Roller Timing Chains
The heat-treated set includeds the necessary oil pump spacers and mounting hardware. The unique crank gear has 9-different keyways to allow for simple adjustments of cam timing.
When used with an ASP crank pulley, modification to the pulley will be required. When using an SLP, or PAP crank pulley, NO modifications are needed.
yes it will fit your car. and i remember now, it is the slp pully, i got it so that i didnt have to machine anything.
and yes, i do accept pay pal
