Brand New 408 Long Block!
408. This motor was for my dad's project but he has decided to go a different direction so he has told me to put it up for sale. The motor is identical to the motor I am getting. This motor will be shipped to the house some time next week. The motor specs are as follows:
11.1 compression
408ci iron block
New 6.0L block
Eagle Forged LS1 Crank 4" Stroke
Callies LS1 Rods
Diamond Pistons
Diamond Pro-Select Rings
Federal Mogul Main Bearings
Federal Mogul Rod Bearings
Clevite Cam Bearings
ARP Main Studs
Custom Cam
LS6 Ported oil pump
Rollmaster Double Adj timing chain
Comp Cams Lifters
Stage 3 Heads
CNC by PRC
Motor comes with Head Flow sheets, Short block build sheet, Warrenty Statement etc..
Motor is brand new and I won't even take it out of crate when it comes if you don't want me to. The motor has a transferable 12 month warrenty as long as the motor stays N/A.
$6,800 obo
I can also get a good deal on shipping so let me know if you need it.
11.1 compression
408ci iron block
New 6.0L block
Callies LS1 Rods
Diamond Pistons
ARP Main Studs
Custom Cam
LS6 Ported oil pump
Comp Cams Lifters
Stage 3 Heads
CNC by PRC
$6,800 obo
I can also get a good deal on shipping so let me know if you need it. Last edited by Mizfit MotorSports; Feb 1, 2007 at 05:05 PM.
I have been playing with the idea of an project car built around a nice 408, my friend also has been wanting to take that step for a while. But I am wondering if you happen to have cam specs on it.
Thanks,
Jim
Thanks,
Jim
