NX Wet Kit
Old May 9, 2006 | 11:52 PM
99ssleeper's Avatar
Default NX Wet Kit
I bought everything used intending to use it, but something came up and I'd like to try and sell what I have. This is the GM EFI NX kit p/n 20920-10.
Fuel and Nitrous solenoids have been tested and they work fine. Bottle is in nice shape, not all scratched up, and includes the mounting brackets, it is empty. Also included is the main line from the bottle to the N2O solenoid, the line that goes to the fuel rail to the fuel solenoid (with an AN fitting for a fuel filter if you want to run one), and the 2' line that goes from the nitrous solenoid to the nozzle. All jets are accounted for and included. I will also include the master power switch, a WOT switch, and the directions for installation. The relay and relay holder is here as well.
The bad....the shark nozzle is messed up...the threads are bad, so that needs to be replaced. The 2' line that goes from the fuel solenoid to the nozzle rubbed on the belt at one time so that needs to be replaced too. The relay holder should be replaced, one of the wires was cut short and frayed. Other than that, everything is here to make a functional kit and new parts should only be about $50.
Everything else looks to be in decent used shape. If you skipped through the above description, I'll break it down for you.
The short list:
-10lb empty Bottle
-Main Line from bottle to N2O solenoid
-N2O and Fuel solenoids
-2' line from N2O solenoid to nozzle
-line from fuel rail to Fuel solenoid
-Power switch
-WOT switch
-All jets from 35hp-150hp
-Installation Directions
Things that are there that should be replaced:
-Nozzle
-2' line from Fuel solenoid to nozzle
-relay holder
PLEASE CHECK MY FEEDBACK. Everything is guarunteed to be as described....need a quick sale, so I'm asking $250 shipped for everything. I'll throw in a few other switches.
PM me with any questions. In the pic, the black thing under the bottle is a piece of plywood the brackets were attached to, I threw that away....also, none of the wiring is there...I was going to do my own wiring (as anyone should) so I removed it all to start fresh. There is no bottle heater included, even though it is in the pic.
Old May 10, 2006 | 12:07 AM
Lithium's Avatar
SSU's Drunk Typing Whore
you serious with that price? count me in if you are.
Old May 10, 2006 | 12:13 AM
zspot98's Avatar
PM Sent.
Old May 10, 2006 | 12:17 AM
99ssleeper's Avatar
Yes I am serious. PMs replied to. Looks like it's pending...
Old May 10, 2006 | 12:22 AM
Harley-Davidson88's Avatar
I'll take it if it falls through
Old May 10, 2006 | 01:04 AM
99ssleeper's Avatar
sold...
Old May 10, 2006 | 06:40 AM
tim99ws6's Avatar
whats paypal, i'll but this second...
