GM Crank Spacer and Ext. Bolts for TH400 Swap
I have a brand new in box GM 6.0L Crank Spacer and all 6 of the extended bolts you need for a TH350/TH400 swap. This was bolted up to the car when I thought I was going to use a SBC converter and then I found a good deal on a converter with the extended crank snout made specifically for the LS1-TH400 conversion. Looking to get $55 shipped. This is $68.94 shipped through GM parts direct. PM me if you have questions. Thanks.
