TNT F1 kit, TNT purge
SOLD!!!!!!!!!!!!!
Ok its offical, Im getting out of the spraying game. I purchased this kit brand new back in oct right after I completed my motor. Its been sprayed about 4-5 times on the dyno & once on the track back in Jan (I beleive it was) That was one full bottle, it hasnt been filled since, the bottle has been sitting in my shop & the rest has still been on the car. Just really havent felt the urge to spray. Now, Once I swaped over to the FAST 90/NW 90 I had to grind the inside of the ring, It did fit on my NW 90mm tb but Ill be honest the grinding wasnt exactly the prettiest. But it worked. I got tired of fighting with it to fit right, so I finally just bought some plastic nuts & drilled two holes in my stock bellow then inserted the nozzles & put the nuts on. This has worked fine for me for the past 3 months. Ill send the power ring also but dont say I didnt warn you. Id like to get $550 shipped to your door for the following.
1- TNT black 10lb bottle with pressue gauge
2- bottle brackets
1- main line
1- TNT nitrous solenoid
1- TNT fuel solenoid
3- fuel lines
2- nitrous lines
jets from 75hp-250hp
1- TNT pro purge kit with the purge lines & "T" fitting
1- TNT Relay
1- Polished power ring (Grinded to fit 90mm TB)
2- TNT nozzles
1- TNT solenoid mounting bracket
all directions
1- WOT switch (lost tiny screws that hold it to the bracket beings I never used it)
1- FPSS saftey switch
I believe thats all, sorry if I forgot anything but if you think of something jsut let me know. It is still on the car & will be removed once bought. Everything you need to spray is here, as its still ready to go, just needs a full bottle & maybe a bottle warmer.
2- bottle brackets
1- main line
3- fuel lines
2- nitrous lines
1- TNT Relay
2- TNT nozzles
all directions
Originally Posted by tim99ws6
I'll take the full kit for 500shipped to 37187
Thanks!
