Anyone in the Riverside area have the ls1 valve spring compressor/reinstaller?
Title says it. I have one, and it takes off the springs just fine, but reinstallation seems impossible. I've been trying for one hour with just one spring
Anyways i'll be outside *attempting* to install them, so if you could give my cell a call (951) 295-0381 and lmk if you have one. I will be able to return it tommorow *if* all goes well. Thanks
Last edited by andrewdruiz; Nov 24, 2006 at 04:30 PM. Reason: Expanded my searching ground
So much for any racing tonight unless I get one tonight. BTW- Autozone/Sears valve spring compressors SUCK!!! The one that you screw in and manually pull down SUCKS to reinstall them!!! And if you build a custom one, be sure to make it out of really thick steel or it'll bend
Achk! Trending Topics
Achk! Thread Starter
Originally Posted by RyneZ06
go to napa, they sell a manual one that you pull down, then cut it to fit, then get the right size bolt that hreads into the heads, or use a rocker bolt your call
