Remote Clutch Bleeder
Old May 31, 2007 | 11:49 AM
  #61
TheLS1Kid's Avatar
Ohhhhh i get it now!
Thanks guys.
I didnt realize there was a valve on the remote bleeder line.
Thanks for the explanation!
Old Jun 4, 2007 | 10:41 PM
  #62
bigsticksupra's Avatar
Thumbs up
Originally Posted by AppleMac
bump ttt
Thanks a lot man! i have successfully made my own remote bleeder line thanks to the parts list you provided. i will try to post pics later. the crush washer and the permatex sealant works fine. you're the man!
Old Jun 24, 2007 | 12:03 AM
  #63
SUPERPOWERS's Avatar
I bought all of the parts on the list and the brake fitting is an inverted flare. The speed bleeder WILL NOT fit inside this fitting. You need a bubble flare fitting. Guess what, there is no -4an-3/8" bubble flare brake fitting!!! I just wasted $94 freekin dollars. The only bubble flare fitting is a -3an-10mmx 1.0.
Applemac did you actually build one of these?
Old Jun 24, 2007 | 12:19 AM
  #64
black2002ws6's Avatar
LPP is a new sponsor on LS1 Tech
We are making remote bleeders for the clutch. With this bleeder you can run it up to the engine compartment or out under the car to bleed the clutch. It also has a speed bleeder on the end so it's a one man operation to bleed the clutch. We are only getting top of the line parts to make them. One of the problems with making them is getting the fitting for the slave cylinder that will seal and not leak since it's not a machined surface. We have found what they call a bonded washer that will seal under high pressure to use on the fitting. We have also found a sealant to use on the threads that will not break down from the brake fluid. This provides a double seal for the fitting. We will be selling them for $75 with Free Shipping. Here's some pictures of them.
If interested you can contact us at lpp@tampabay.rr.com
Old Jun 24, 2007 | 12:22 AM
  #65
Country Boy's Avatar
Senior Member
Im glad someone actually knows what they are ordering. Sorry you had to waste $100.
Old Jun 24, 2007 | 12:47 AM
  #66
if I had known that this was going to be such a pain I would have just ordered the kit!! I can't seem to find a -4an x 3/8 female bubble flare fitting anywhere. I am going to have to try and machine the inverted flare fitting. I am pissed. I can't take the parts back either. I now live 3.5 hours away from the speed shop that I got the parts from. ahhhhh!!! See what happens when you try to save a buck. Someone needs a beating!
Old Jun 24, 2007 | 01:02 AM
  #67
That's why we spent months trying to find all the parts that work perfectly together. We ran across a few setups that may or may not have worked but that wasn't good enough we wanted a set up that was perfect. We finally found all the parts to make a perfect setup. So far we have sold over 50 of these setups with only one problem. One customer had a bleeder fitting leaking and it turned out to just be a bad bleeder valve.
Old Jun 24, 2007 | 01:10 AM
  #68
are you will to help me fix my current setup? are you using -3an hose or -4an hose?
Old Jun 24, 2007 | 11:34 AM
  #69
Tootall's Avatar
this wasn't it?
http://store.summitracing.com/egnsea...nresults=false
Old Jun 24, 2007 | 11:41 AM
  #70
Senior Member
Look at the description... "Inverted flare".....
Old Jun 24, 2007 | 12:00 PM
  #71
Originally Posted by Tootall
no you need a buble flare fitting, guess what there is no -4an bubble flare fitting. there is a -3an bubble flare fitting, but there is no adapter from -4 to -3. So you could use a -3an line but there is no fitting that goes from the -3an line to the 10x1.5 slave. Maybe apple mac should have built one first
Old Jun 25, 2007 | 08:04 AM
  #72
Thaniel's Avatar
Yah the "buble flare" or concave fittings are harder to find. And some places have them but it is hard to tell if it really is the right one (summit for example)
However they are out there. I used Pegasus 3265-19 Female 10 x 1.0mm Metric Concave Seat to 4AN, Steel . then I bought a 10mmx1.0 bleed valve from napa. The bleed valve was $2.00 the fitting was like $5. My whole remote bleeder was around $40. Doing it myself didn't save a lot of money but I did learn a lot.
From my reading for high pressure lines like the clutch and brakes aluminum fittings are not recommended. All fittings I used in my set up are steel.
The parts I used starting at the slave cyl are.
1. 10mm crush washer
2. -4 to 10mmx1.5 metric adapter (Aeroquip FCM2967 or Goodridge 305-04-35P)
3. 36" of -4 teflong brake line with Straight/Straight Swivel fitting ends (BL-6104-36) 36" is probably too long.
4. Female 10x1.0mm Metric concave seat to -4 Steel (pegasus part# 3265-19)
5. 10mmx1 bleed screw (bought at NAPA).
Part 4 and 5 could have been any thread that matched and not 10mmx1.0
Here is a link to a blog of mine with more info on what I did for mine. http://www.ls1bmw.blogspot.com/
Link to the actual clutch bleeder page: http://ls1bmw.blogspot.com/2007/06/c...leed-line.html
Old Jul 30, 2007 | 11:05 AM
  #73
Sharpe's Avatar
Old Sep 2, 2007 | 03:33 PM
  #74
striker754's Avatar
has anyone else used this method?
Old Mar 6, 2008 | 08:32 PM
  #75
98RedZone's Avatar
Just got this slave a couple days ago from gmpartsdirect. You can't tell from this pic, but it is machined flat. PN 15046288
Old Jan 26, 2009 | 06:42 PM
  #76
Wo0111's Avatar
I bought all these parts from summit--where do the speed bleeder screws go--they do not fit any of the listed parts
Old Jan 26, 2009 | 06:44 PM
  #77
Another customer screwed up by miss information
Old Jan 26, 2009 | 06:46 PM
  #78
This is why we spent months coming up with the right combination of parts that works perfect. And to date have sold over 400 of them without any issues.
Old Jan 26, 2009 | 06:52 PM
  #79
Thaniel's Avatar
Which parts did you buy? These two parts go together:
part#4 I did not see available at Summit. Perhaps you have the wrong part.
See link http://ls1bmw.blogspot.com/2007/06/c...leed-line.html for how the parts are layed out.
Old Jan 26, 2009 | 06:54 PM
  #80
Thaniel's Avatar
I resent the fact you infer I am giving incorrect information. The parts list is EXACTLY how it goes together and does work. Been on the car for 1.5 years and not a drop lost.
