Progressive Vortech install with Pics and Q's
Got another question, the line coming from the left side of the power steering pump...I don't have the replacement hose (previous owner didn't send it). Can I just bend down the aluminum line straight down to make it clear?
Ha good point on the leaking...I sure did bend the heck out of those lines. lol I don't think I cracked any of them though.
Do you know how much psi this line see's? I ask because i'm wondering if I can just cut the piping near the end fittings and clamp on some new rubber hose. Here's a pic of one with rubber hose.
I am going to call Vortech tomorrow and see if they can sell me this replacemtent hose.
Does anyone know how the actual fitting stays on top of the power steering pump? I know it has the little clip that clips above it but the fitting must lock in to the top somehow.
Jeff
Any pics?
Yeah I don't think i'm going to be using the stock hose and fittings. I was able to call vortech and get the sizes for the fittings that usually come with the kit.
It bolts on to the surecharger bracket. And holds the return in place. Not hard to make at all. When I did the g trim kit and T trim kit they were missing. And I didnt want to wait for vortech. Both kits are running around with no problems.
With the fitting for the oil feed line it says to drill it with a "R" drill bit and tap it with a 1/8" NPT. Do the "R" drill bits come in multiple sizes or is it specifically one size? Could I just use a 1/8" drill bit?
So I called Vortech to get the fitting sizes for the power steering pump and I wanted to see if anyone knew where to get these type of fittings. If anyone know's part #s that would be great.
Female Mount to Male:
-6 JIC
-6JIC W/ 90 degree
Bump Fitting
-6 M16 x 1.5
-6 M18 x 1.5
-6 JIC
-6JIC W/ 90 degree
Bump Fitting
-6 M16 x 1.5
-6 M18 x 1.5
