I have now started my direct port build(NXL)
dude thats sick!!!!!!!!!!!!!. thanks for the fuel accum by the way. wouldnt happen to have any pics of where you mounted it do you?
and would there be a way to spray out the grill on an SS hood?
Your in luck, I actually found a couple. Look in the lower left corner. You will see the blue fuel line going from it to the rear of the engine. As for purging out the grill, just run your purge line to where ever you want it to exit. As for me, I want my purge where I can easily see it in bright sunshine.
The bottom line is a drain in case the diaphram in the accumulator fails.
GoldZ: Nice setup, I see you opted for the stainless steel braided hose going to the injectors instead of the black hose like me. Looks good
Originally Posted by sidewayz28
whats a drain? never heard of it?
Closed ex-Sponsor Account
Originally Posted by mrr23
as stated, it's if th rubber diaphram inside theaccumulator ever went bad and started filling up with fuel on the wrong side, it has a place to dain out.
well, i talked with ricky some about it. you could hook it to a vacuum port, so it'll pull more fuel into the accumulator. downside is if it does leak, it goes into the motor and cause a rich condition.
thank you robert i appreciate it! ive got some qs about tuning.. i was thinking of having ellis install most of my kit as well as the tune.. do you suggest using a dyno for tuning with nitrous?
thank you robert i appreciate it! ive got some qs about tuning.. i was thinking of having ellis install most of my kit as well as do the tune.. do you suggest using a dyno for tuning with nitrous?
Robert
should be done here in the next few weeks!
