Spec 3+ with Spec Alum. Flywheel
Old Oct 13, 2008 | 07:48 PM
TheBiz's Avatar
Default Spec 3+ with Spec Alum. Flywheel
Clutch came out of an 02 Z06. Clutch and flywheel have 1000 miles on it. There was a small shake in low RPMs. Called spec and they said it was a balance issue. It was pulled and replaced anyway. Removed the clutch and it looks fine. I would have the flywheel balanced again and surfaced just to be safe.
Clutch has LESS than 1000 miles!
$500 SHIPPED! I can have it surfaced prior to shipping for an extra $75.
Pics will come later this week.
*EDIT* Clutch and flywheel were taken to a local machine shop yesterday. He said it did not need balanced, and that it was fine. He also said everything looks good and he would have no problem running the clutch in his own personal car the way is sits. I'm pretty sure the shake, chatter, wobble, whatever you want to call it...was caused by a bad pilot bearing.*EDIT*
SOLD
Attached Thumbnails Spec 3+ with Spec Alum. Flywheel-spec3-001.jpg   Spec 3+ with Spec Alum. Flywheel-spec3-002.jpg   Spec 3+ with Spec Alum. Flywheel-spec3-003.jpg   Spec 3+ with Spec Alum. Flywheel-spec3-004.jpg   Spec 3+ with Spec Alum. Flywheel-spec3-006.jpg
Old Oct 13, 2008 | 11:07 PM
Spectre86's Avatar
bump for an honest guy
Old Oct 14, 2008 | 02:16 AM
2resonate's Avatar
sending PM, Kurt
Old Oct 14, 2008 | 06:38 AM
TheBiz's Avatar
Thanks man.
All PM's have been replied to. I should have pics tonight.
Old Oct 14, 2008 | 09:44 PM
Domexitium's Avatar
will this work on a t-56?
Old Oct 14, 2008 | 10:09 PM
Pheonix's Avatar
So the clutch you are selling is the one that shakes or that is the one you replaced?
Old Oct 15, 2008 | 08:11 PM
TheBiz's Avatar
Yes, it will work with a Vette or F-body t-56. LS1 car of course.
Old Oct 15, 2008 | 08:16 PM
TheBiz's Avatar
Yes, this is the clutch that HAD the shake. Spec said they think it was a poorley balanced fywheel. I think it was a bad pilot bearing that caused the vibration. I would recommend balancing the flywheel just to be safe.
Old Oct 19, 2008 | 07:28 AM
TheBiz's Avatar
Bump, pictures of clutch should be posted today.
Old Oct 19, 2008 | 09:29 AM
spaz1's Avatar
When you said shakes, do you mean chatter while engauging or the engine shook while it was sitting there idling? was it worse when you reved it up?
Thank,s
Old Oct 21, 2008 | 06:29 AM
TheBiz's Avatar
No shake at idle. just when you let the clutch out. I actually took the flywheel and clutch to a local machine shop yesterday to have it balanced, and he said it was fine. The did not have to do anything to it. He looked the whole setup over and said he would run it the way it is. I'm betting the worn out pilot bearing in the Vette was causing the problem. I have pics, I just need to post them.
Old Oct 21, 2008 | 12:48 PM
beezer1519's Avatar
very interested please post pics
Old Oct 21, 2008 | 05:44 PM
TheBiz's Avatar
Pictures added in post #1. Just something to think about...at $500 shipped, you are getting a $700+ clutch and flywheel for about $400 plus shipping. Its going to cost me a pretty penny to ship this sucker. Its heavy.
Old Oct 23, 2008 | 06:27 AM
TheBiz's Avatar
Bump.
Old Oct 24, 2008 | 04:28 PM
TheBiz's Avatar
Bump...still available.
Old Oct 25, 2008 | 07:04 AM
TheBiz's Avatar
Up for the morning. Got some offers.
Old Oct 26, 2008 | 07:13 AM
TheBiz's Avatar
Up again.
Old Oct 27, 2008 | 06:37 PM
TheBiz's Avatar
...and again.
Old Oct 27, 2008 | 07:03 PM
TheBiz's Avatar
Its going on eBay.
