Alot of 93-02 F Body parts
Old Oct 15, 2008 | 10:24 AM
superssport's Avatar
Default Alot of 93-02 F Body parts
Its time to clean out the shop. I have a long list of parts for 93-02 cars. All parts are plus shipping. I am going to the lsx shootout so I can bring any of these with me. For a faster response email me at nathanpfeifer@hotmail.com
LS1 Specific
Cam retainer plate SOLD
MSD spark plug wires used SOLD
Rocker arm guides 15
New water pump gaskets 5
LS2 block needs resleeved 200
LS2 crank needs to be turned 100
Coolant tubes SOLD
32k timing set 20
32k oil pump 25
8 rocker arms SOLD
Firehawk hood grills 25
Lifter trays 15
15 32k pushrods (lost 1) 5
Master cylinder U bolt SOLD
Intake bellows 10
Thermostat 5
Oil pan bolts SOLD
93-02 parts
LT1 2 cats 150
Trans Am drivers side ground effect red 95
Ebony drivers side kick panel 20
Ebony rear deck panels with speakers (camaro) 45
Ebony a pillars hard top have tweeter holes cut out 35
Graphite grey trans am dash vents 4 ea. or all 3 for SOLD
Graphite grey sail panels 40
Graphite grey kick panels 25
Graphite grey a pillars 25
Graphite grey carpet 70
Graphite grey complete seat belt set 45
Graphite grey dome light 5
Graphite grey Trans Am window switches 35 set
Seat belt guides 5 ea.
Trans Am headlight switch 10
Passenger side airbag 50
Hood hinges 15
93-96 tail light harness 20
Electric fans 75
2 sets of sunvisor mounts 15 ea.
Camaro rear speakers 20
Trans Am sail panel speakers 35
Bunch of felt window guides 5 ea.
E brake 15
A4 shifter 20
A4 pedals 25
Windshield cowl 15
Red TA mirror SOLD
Mirror brackets 15
Hatch release 15
Window regulators(power) 25 ea
White Z28 spoiler 25
Drivers side t-top seal 35
T-tops set 140
Torq Thrust 2 TT2 center cap new 15
LT1 Parts
Oil pan SOLD
Power steering 20
Valve covers 15
95 A4 engine harness 75
95 body harness 100
Intake elbow 15
Fuel rails 30
Injectors 40
Water pump 15
Alternator 25
Optispark (vented) 25
95 timing cover plugged for elecric water pump 40
Old Oct 15, 2008 | 04:42 PM
72chevelle6.0's Avatar
can i get a picture of the coolant tubes? Are they the ones for the heads?
Old Oct 15, 2008 | 06:53 PM
Nick_Rapitis's Avatar
pics of a4 shifter handle please...nick_rapitis@msn.com
Old Jan 15, 2009 | 10:21 AM
BrOdBaNd's Avatar
Default Ebony hardtop a pillars
I REALLY NEED THOSE EBONY HARDTOP A PILLARS. Send pics to brodband8@hotmail.com
Old Jan 15, 2009 | 11:57 AM
Pics sent and list updated.
Old Jan 15, 2009 | 12:31 PM
kenglish's Avatar
I HAVE A 1998 CAMARO, silver with grey leather
Looking for the following parts
1. Front plastic inner fenders
FOUND------2. Window retainer (this is the pad under the door card that holds the
window straight up)
3. Fog lights and (I need the plug for one of them, mine is cut off from the
wiring on my car)
4. I need a FRONT (driver or pass) grey leather seat cover, I dont care if its ripped I work at an apholstery shop so we will cut the back off a ripped one and use that leather the repair my fronts.
5. Ground effects I have a drivers side, but would buy an entire set
6. I need a heater control ****...JUST THE **** HOT/COLD altho I think
all of them are the same
FOUND------7. Drivers door hinges
FOUND-------8. gas neck plastic part that screws to the car and holds the gas lid
9. rear interior clips/locks that hold the trim in place (speaker side trim) grey
10. windshield if you live close to me I can pic it up
FOUND------11. Rear Hatch motor
12. Outside Drivers side window sweep
13. Throttle position sensor
FOUND------14. Headlights
