bye bye Mr.Trex :( ... need some help..ls7 lifter failure w/Pics
so it appears that Mr.trex and i were not meant to be....
i'll let the pictures tell the story...
Cam
Lifter
so my question is what coulda caused this...
Cam
Lifter
I had a lifter come out of an LT1 looking like that on me before...the lifter guide had failed (LT1's have a spider in the valley that holds the guides down, and it bent up and let a guide free) which caused the lifer to spin in the bore and then the roller wasn't rolling on the cam anymore...in an LS1 the guides are plastic and totally different, but the principle is the same, how does the lifter body fit into the guide? Could the lifter have rotated in it's bore?
Scary! Wondering now weather or not to go with the Ls7's on my cam swap...? That missing chunk stay up top or are you gonna have to pull the pan to get it out? Good luck.
to much work to pull the pan, so its gonna stay like that, and being the cam bearings look good im gonna say the mains should be ok too... just tired of it, if something happens now shes gonna sit till i build an stroker
i just dropped the motor a few months ago, to inspect and swap in the trex and new lifters.... lifter bore appeared to be ok... the tray held the new lifter just fine. nope stock trays from the motor...
ahh im just tired of it... stock she goes... well, LS1 stock.
I prefer Morrels then, Comp R lifters are a pain in the **** when it comes to preload.
I run 850-16 in all my motors to 7000 rpm. and up to .620 lift with 0 issues to date, proper geometry and preload a must.
