non-LSX Parts For Sale SBC, LT1, V6, etc.
TH400 switchpitch chevy 3:00 gear set
Old Oct 25, 2008 | 10:47 AM
Yank's Avatar
Default TH400 switchpitch chevy 3:00 gear set
I have a TH400 Chevy short case Switch pitch transmission with a 3.00 low gear ,1.57 sceond gear 1.1 third --- Kilgore gear set (this Gear set cost $1200.00 alone) ---the trans is a full auto shift with a manual override valvebody Deep pan HD sprag, and HD build thansmission has a special output shaft that uses the 350, PG , 4L60 or M-6 style out put shaft yoke
includes special built YANK converter with 3500 high stall and 2800 low stall
this is switched with a 12 volt wire powering the stall switch feature
Flip the switch and you have your choice of stall speeds!
Great as you can drive to save gas or switch to the high stall any time for some street/strip action
This trans has 3000 miles and has worked flawlessly
it will direct bolt up to and Chevy V8 engine can be used on LS engines with a crank pilot adapter
I have $4500.00 invested in this
SOLD
mike@converter.cc
Old Oct 25, 2008 | 11:05 PM
gcpoland's Avatar
Would like to call and talk about this. When would be the best time.
Gary
Kingston,NH
Old Oct 26, 2008 | 07:54 AM
Yank's Avatar
Gary
Kingston,NH
You can call me at 479 632 6355 after 10:00 today or email your # and I will call you mike@converter.cc
Old Oct 26, 2008 | 01:16 PM
Yank's Avatar
to the top
