P1SC with Custom Bracket
Old Oct 26, 2008 | 01:04 PM
Aster's Avatar
Default P1SC with Custom Bracket
It's taken me a few months of parts collection and design work, but I have finally gotten close to having my project done. I have been piecing together my own procharger kit changing out some of the pieces for my own or what I hope will be better.
For cooling instead of getting the procharger supplied fan I went with a Spall 16" Paddle fan - model 30102082. They say it is good for almost 2500 CFM and so far I haven't had any cooling problems.
I designed my own tensioned bracket for an 8 rib belt to run the blower with, which was the fun part of the project. It's spinning my blower to almost 53000 RPM without so much as a twitch. Nice and steady all the way to the top of the run. The boost is a little on the high side though around 9 to 9.5 psi using the ATI 8 rib 7.625" crank pulley and a 3.85" blower pulley. I'm hoping to get a second bracket made for testing on a bigger blower.
I made the J wider so there is more material to hold it and also added another bolt position in the bracket to use the other 3/8" bolt hole on the Procharger. Hopefully this will prevent any flexing issues that people have said about the regular ATI bracket.
I run the belt similar to the SDCE setup except I had a small pulley machined and new standoffs for the bottom post to run the belt back over the top. All told it gives me a huge amount of belt wrap.
What's even better is I can do the belt myself without any "special" tools. A regular 15mm wrench is all that is needed, which barely fits between the tensioner and the power steering pulley. I figured there shouldn't be any reason I can't use the same tools on all my belts.
I used the 8 rib pulley from RevXtreme on the tensioner which is a nice piece. Only thing I had to do was re-press in the bearing using Loctite 620 retaining compound. It was walking off the bearing at first. No big deal the Loctite has held it rock steady ever since. This is nothing against Tracy, he was great to work with and offered to replace the whole thing, but it wasn't that big a deal and easily fixed, since I had the Loctite already for my two custom pulleys for the bracket.
Here's a pic of belt installed. You can see the new LS3 water pump I used to make sure I had plenty of clearance for the belt. The regular LS1 pump looked like the belt would rub.
I finally got it on the dyno for turning Friday night. IAT's were great, tuner said they were around 102* through the baby intercoolers (I'll have to keep my eye out for the 4.5" twins though by summer time.) He kept the tune conservative given the stock bottom end with timing pulled out and fuel between 11.8 - 11.5 on the big end. Tuner says we should go to an SD tune since we're pegging the MAF at around 5500 RPM. He also believes it will cure some drivability issues I've got with surging and the AC on (These have been around since the cam).
Anyway onto the fun part.
So far the car made 546 rwhp/503 tq, under the curve it is making 400 tq at 2900 rpm, and 442 tq at 3500 rpm. Not bad for a baby procharger on a 112 lsa cam.
Here's the dyno graph from the last run we did of the night.
Not sure if the numbers will change much going to an SD tune, but I do hope I can start the car with the AC on or not have to worry about it stalling/hunting all the time when I come to a stop.
I want to thank Tracy at RevXtreme and Bob at EPP. They helped me collect the miscellaneous pieces I was missing for the kit and they were happy to spend time talking to me about the plans and setup even though I wasn't spending lots of money with them. You can't go wrong with either one of these guys.
Old Oct 26, 2008 | 01:25 PM
'Trust''s Avatar
Looks like a really nice setup, but I've never had flexing issues on my ATI bracket making 14psi and 660RWHP....
Old Oct 26, 2008 | 01:31 PM
Aster's Avatar
I'll believe it, was just going off what I'd read on here so I figured I'd just try and make it as good as possible. I didn't ever want to have to go back and redo it if I ever go bigger.
Old Oct 26, 2008 | 03:38 PM
Rickys S/C Z28's Avatar
wow man nice set up you have a pm
Old Oct 26, 2008 | 04:29 PM
Aster's Avatar
Thank you Ricky, you have a response...
Old Oct 26, 2008 | 05:07 PM
nvmy2000ss's Avatar
Very clean setup.
Old Oct 27, 2008 | 02:44 PM
Aster's Avatar
Speaking of going SD in my first post... is there a direct replacement 2 bar MAP sensor I can put in my intake? Dunno if the ones from the Supercharged W-Bodies would fit or not.
Thanks for your help.
Old Oct 27, 2008 | 04:30 PM
there is one from a coblt that works great!!!
Old Oct 27, 2008 | 04:42 PM
Aster's Avatar
Cool, I'll search around and see if I can get the part number for it. Thank you!
Old Oct 27, 2008 | 05:40 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Nice! how much to make me one?
Old Oct 27, 2008 | 07:01 PM
Slowhawk's Avatar
LS1Tech Sponsor
Very nice looking piece.
So far I've gone 900rwhp with the stock J-bracket with no belt problems.Just lucky I guess.
Old Oct 28, 2008 | 01:11 PM
Aster's Avatar
Old Oct 28, 2008 | 01:54 PM
xBROKEx's Avatar
looks good, i need to remember to pick my j bracket up from you one of these days
Old Oct 28, 2008 | 02:12 PM
Aster's Avatar
Yes you do. Again (see AFB post) thank you for letting me borrow it. Made getting measurements so much easier.
Old Oct 28, 2008 | 02:20 PM
Big Bird WS6's Avatar
looks good. you do the work?
Old Oct 28, 2008 | 02:29 PM
Aster's Avatar
I did the bracket design and all the CAD drawings, I then took those to a machinist to have then produced either on a CNC mill or a lathe.
I put the whole thing on the car though. Everything from the fuel to the blower and intercoolers and piping, to wiring the fan.
Overall the install wasn't really difficult, just time consuming.
Old Oct 28, 2008 | 08:59 PM
xBROKEx's Avatar
oh **** i missed it on there and completely forgot about it, since im still tryin to nail my tuning ssues down
Old Nov 4, 2008 | 02:47 PM
Aster when you work out what the bracket will cost please send me a PM
Old Nov 4, 2008 | 06:25 PM
bigsticksupra's Avatar
wow you're the man! please make a 10 rib or 12 rib system with the the sd type tensioning system!
Old Nov 4, 2008 | 08:47 PM
9t8z28's Avatar
I'm in!
