Billet Specialties Street Lites 15" and 17" Info And Pricing
Old Oct 27, 2008 | 05:58 PM
Dragwheelz.com's Avatar
Default Billet Specialties Street Lites 15" and 17" Info And Pricing
I keep getting the same Pm's asking about fitments.
Front
15x4 We have a Fittment available that works with slight grinding of the caliper as seen in these photos. The grinding is not severe to aid in the failure of the caliper. With the design and construction of the 2pc wheel, It is the only option available.
17x4.5
In devolpment. I will be releasing details as they come available.
17x7, 17x8.5, 17x9.5
Available as a Direct Bolt on, No grinding needed Just bolt on and go. Will Not Clear C5/C6 or Wilwood Calipers.
Rear
15x10 We offer a Direct Fit wheel, No grinding is needed at all. Bolt on and go. ( this is them with the 15x4 )
17x9.5 , and 17x 11 Direct Fit wheel, No Grinding Needed at all. Bolt on and Go.
Pricing
15"
15x4 Jobber is 253.56 ea ls1 tech pricing is 230.00 shipped
15x10 jobber is 359.11 ea Ls1tech pricing is 330.00 shipped
If you buy a set of Fronts and Rears I will sell them Shipped for 1100.00
Lugs are 40.00 for a complete set. If you just order 1 set of wheels Lugs are 20.00
17"
17x7 jobber is 270.00 ea intro pricing is 250.00 shipped
17x8 jobber is 295.00 ea intro pricing is 265.00 shipped
17x9.5 jobber is 315.00 ea intro pricing is 290.00 shipped
17x11 jobber is 340.00 ea intro pricing is 315.00 shipped
Lugs are 40.00
No Special handling fees or anything else. shipped price is final price.
I have these In stock and Ship within 48hrs of Payment.
Stay Tuned for Some More New and Exciting news.
Old Oct 27, 2008 | 06:22 PM
socmguy's Avatar
Restricted User
Those 15x10s look awesome! I may be buying very soon.
Old Oct 27, 2008 | 07:32 PM
jcoker's Avatar
any chance of a 17x4 coming out
Old Oct 27, 2008 | 07:53 PM
Camaro396's Avatar
He said they are in development.
Old Oct 27, 2008 | 08:40 PM
CoopZ06's Avatar
Default Question about your wheels
Will the 15" wheels fit a 2001 Z28 with Strange front drag brakes and stock ls1 rear breaks?
Thanks,
CoopZ06
Old Oct 27, 2008 | 08:47 PM
Stangkilr's Avatar
Which 15x10 backspacing would I buy if I have a rear end narrowed 2.5" each side?
Old Oct 27, 2008 | 08:49 PM
94'BLKBRD's Avatar
Question about the pictures of 17'' wheels. Is the rearend on that Trans Am narrowed or is stock length? Curious on the dish size
Old Oct 27, 2008 | 09:30 PM
Camaro396's Avatar
I believe currently the only backspace offered in the LS1 style hoop, is the 7.5" for standard length rearends.
Old Oct 27, 2008 | 09:31 PM
Camaro396's Avatar
Thanks,
CoopZ06
Yes, they will.
Old Oct 27, 2008 | 09:32 PM
Stangkilr's Avatar
Im running drag brakes.
Old Oct 27, 2008 | 10:10 PM
Camaro396's Avatar
Then you should be fine with the standard non LS1 specific Billet Specialties wheel, in the backspace of your choice.
Old Oct 28, 2008 | 12:03 AM
Thanks,
CoopZ06
Yes they will.
On the front you can use the 15x4 or the 15x3.5 and the Ls1 specific rear wheels.
It is a Stock Length Rearend in the car. The dish you see is what you get.
Whose Drag Brakes are you running??? if they are strange you should not have an issue, I have heard some complaints of them not Fitting on Aerospace, But other people have not said they had a problem.
You can utilize the regular 15x10 with drag brakes. your price on those would be 230.00 ea shipped to you. here are a few pics with them with Strange Drag Brakes and a narrowed rear end.
Old Oct 28, 2008 | 12:32 AM
SuperZ's Avatar
Are the center caps on these the same i noticed the 17s didnt have center caps.I want the 17by8s amd 15by10s!
Old Oct 28, 2008 | 01:28 AM
yes the center caps are the same. On the 17" i did not put them on as they were test fit wheels to make sure the backspace was correct and no rubbing.
If you are intrested in ordering please Pm me. I can ship them out this week.
Old Oct 28, 2008 | 03:25 PM
Here is a newely released Piece to Compliment your Street Lites.
14" Street Lite Steering wheel. have the Billet Adaptors to remove the Airbag also.
( off road use only )
Old Oct 28, 2008 | 04:54 PM
Stangkilr's Avatar
What is the exact setup on that blue car?
Old Oct 28, 2008 | 05:07 PM
15x10 in the rear Non ls specific narrowed 3" each side
15x3.5 in the front
strange drag brakes all around
Old Oct 28, 2008 | 05:38 PM
Stangkilr's Avatar
15x3.5 in the front
Thats what I want then, Think I could get away with 2 narrowed each side with 5.5 b/s? I think i might run the wilwood drag brakes.
Old Oct 28, 2008 | 06:03 PM
I know for a fact the Strange fit no problems whatsoever.
the wilwood rear kit has an issue that will not work with my conventional wheel, that is from the center line of the axle to the outside of the caliper is 7.10". the conventional hoop has a maximum of 6.5625 so they will not fit.
Deducting 2" each side will bring you to a 5.5 Bs.
Old Oct 28, 2008 | 07:08 PM
Stangkilr's Avatar
Looks like im buying the strange brakes then. Thanks man!
