Chromeoly Nitrous Driveshaft, 3.55 9" Gears, C5 Brembo Brakes, Injectors, LCA RLB
Got a low mileage Speed Inc. HD Chromeoly Nitrous Driveshaft that is 1/2
inch shorter than stock so that it works well with a stock rearend and
will work well with a 12 bolt as well. It has stock size u-joints (not
1350). This driveshaft was the solution when I snapped the stocker on
street tires. I went to a 9 inch rear now so I had to have a longer DS.
Driveshaft is sold!
3.55 Gears from a 9 inch. I put about 300 miles on these gears and the
shop I bought the rear from said they put about 1000 on them so they are
pretty new. There is not much wear on these gears as you can see. There
was only a little whine around 60-70mph.
Gears are sold!
C5 Rear Brembo Blanks SOLD
Stock 28.8 Injectors $60 Shipped SOLD
UMI Lower Control Arm Relocation Brackets (I do not have the spacers for
these just the brackets that you see pictured but it is $18.94 shipped from UMI) $50 Shipped for the brackets
New Valley Cover Bolts for FAST Intake: $25 shipped
I also have brakes off my 01 WS6:
1 set of LS1 Fbody front and rear calipers: 120 shipped
Rear LS1 Fbody Calipers clearanced for drag rims: 45 shipped
Rear LS1 Fbody Blank Rotors that came on my 9 inch when I got it and look fairly new: 25 plus shipping
I can get pics of these items if needed
Driveshaft is sold!
Gears are sold!
