50 pairs of Bazooka 6.5" DVC Subwoofers Back in Stock!!
Well guys after waiting for these for 3-4 months SAS Bazooka finally got a container in and I got half of the 200 6.5" DVC subs that were on it.
I have received numerous PM's about when I'd get these back in stock so I am posting up to let you know they are back in stock at the regular price of $119.00 a pair shipped and I have activated the "Buy Now" button status on the website for easy ordering.
For those of you who are looking for a better then stock replacement but don't want to go aftermarket amplification these are for you. These are the correct 6.5", dual 4ohm voice coil design like the stock subs in the Firebirds Monsoon system. These will also work in Camaros by wiring the coils in parallel to achieve the 2ohm load. Better then stock in build quality and will handle more power.
I will also be including these in my F-body speaker packages standard in the regular package and optional in the premium package. This actually saves you money when purchased this way.
Here are links to the site for the subs and the speaker packages:
Bazooka 6.5" DVC subwoofer: http://www.keeaudio.com/id72.html
F-body speaker packages: http://www.keeaudio.com/id79.html
I will also be doing a Holiday Special soon on several CDT products so this is a perfect time to pick up a quality coaxial speaker, component speaker set or subwoofer. For the 3rd gen guys I will also be putting something together for those cars!!
I still have 3 special deals left on the new CDT high end SQA-4100 4-channel amplifer as well!!!!
The materials, voice coils, design, and contruction are much better then stock. They also handle way more power then the stock subs. They use a stiffer treated cone structure with a much thicker surround which is good for about 10+mm of excursion. The basket, while still being stamped steel, is stout. I put one of these through a pretty abusive test recently and it handled what I threw at it very well.
Do you have these that work out of the box for a Camaro? I have a blown sail panel speaker and I want to replace them both as simply as possible. If not is there a write-up on wiring these into a camaro? All the searches I found was just for Firebirds
All you have to do is wire them like the first picture top left (Which is what Pentavolvo and I mentioned) to make them work in your Camaro. I can wire them for you if you need me to.
i think alot of people are just looking to replace there blown stock ones with something of same quality or slightly better without paying dealer prices for the pos monsoon ones but i agree
The stock subs are cheaply made and use cheap materials. The Bazookas use much better materials and have a much better design over the stock subs. They also have larger 1.5" aluminum voice coils over the stock 1" copper voice coils. I'd say that's more then a slight upgrade over stock.
If you are talking about my sig, then yes. at G12
That's what I thought! I was a sponsor there this year. I just put some very nice components on sale from CDT and could do a package for you if you wanted. Packages include shipping costs and get the speakers discounted a bit.
If you install them correctly they won't vibrate. By this I mean that they should be securely mounted. They should not vibrate any more then the stock ones did.
Another good investment for these would to install a Dynamat Speaker kit. This dampens alot of vibration that may occur. Plus it is only a $21.00 investment and is very easy to install with them. 1 kit does both speakers.
