Bf Goodrich g-force t/a kdw tires
i have 2 brand new Bfg's for sale...size is 245/40/18,they are brand new and never been used....they are the stock tire size on stock c6 corvettes
i will post some pics up of them when i get a chance
new they are 200.00 a piece new,im asking $250.00 for both and they are new!
Most of us live in climates where we can expect wet roads a good portion of the time. For those seeking g-Force maximum handling and traction whether it's wet or dry, then here's your tire. Key product application Dry and Wet, the g-Force T/A KDW gives you the confidence to take control of the most demanding roads imaginable while delivering an exceptionally quiet ride. A perfect match for the world's finest sports and touring cars.
•Unidirectional tread design gives exceptional dry and wet traction and handling with low noise.
•Large block elements enhance stability, wear and handling under high torque loads.
•Deep, wide circumferential grooves reduce hydroplaning for confident wet traction.
•New proprietary Black Tech™ tread compound delivers excellent wet and dry grip (UTQG = AA).
•G-Control™ sidewall inserts resist deflection and generate tremendous cornering force.
•Dimensionally stable polyester casing plies, ETEC System™ provide excellent strength, smooth ride, consistent footprint and maximum tread contact area under high speed conditions.
•Y-speed rated (up to 186 mph)
haha copied the descriptions from discount tire
hmm that sounds like a good deal if i had 18 inch wheels....the reason im selling these is cause i was gonna buy some 18wheels from a member and at the last minute it didnt go threw and i had already gotten these tires....i would be will to accept 16 inch drag radials for my oem snowflake wheels or 15 inch drag radials for my centerline warriors
Well yah got me there...I don't even think in 15" or 16" any longer. Would you be interested in purchasing the rear 18" Y2K wheel set with the current Nitto's? You could then keep your street tires and have a set of drag radials as back up on a set of REALLY light good looking wheels?Not interested? No harm no foul.
Just business.
