Fast Flash LS1 programmer
Old Nov 27, 2008 | 07:27 PM
DKITCHEN's Avatar
Default Fast Flash LS1 programmer
SOLD SOLD SOLD, thanks for looking!
Over $350 new. First $150 shipped gets it. It's unlocked and ready to use on your car! Several great features in addition to the tuning benefits. Reads and erases trouble codes and displays alot of live engine information, like coolant temp, speed, rpms, o2 sensor readings, intake air temp, fuel trims, and much more. Here's some info:
Boost LS1 Horsepower Without Lifting Your Hood!
The FAST FLASH ™ Power Programmer - GEN III Horsepower Without Wrenching
With the FAST-FLASH™ Power Programmer, you no longer have to trade economy for performance. The FAST-FLASH™ Power Programmer plugs into your vehicle’s diagnostic port, saves the factory tune to memory, and in just minutes, reprograms your engine and transmission settings for the kind of performance that you desire. If you want to restore your stock tune, the FAST-FLASH™ programmer can easily reinstall it. FAST-FLASH™ offers three distinct settings to choose from: performance, towing, and economy.
The Performance Tune setting is for all out power and acceleration. Adjustments include advancing the engine’s ignition timing up to 10% (burning more fuel and air for maximum horsepower), and removing power robbing OEM torque management by allowing optimum ignition timing and maximum transmission engagement on full throttle gear shifts. The FAST-FLASH™ Programmer also increases your transmission shift points upward by an additional 4 mph, keeping your engine rpm up for fast acceleration.
Have you ever considered swapping a hotter cam into your LS1, only to be scared off by that “computer modifications required” footnote on the spec page? FAST™ has got you covered - with our exclusive Cam Tuner Technology™. By simply selecting one of three built-in camshaft settings, you can instantly optimize your engine tune to make maximum horsepower using performance camshafts ground with up to 230° of .050’’ duration!
The Towing Tune setting is for hauling heavy loads. This tune optimizes your GEN III’s ignition timing, torque management, and shift point settings - maximizing torque and protecting your expensive transmission from damage when towing a heavy load.
The Economy Tune setting helps you to save fuel. This tune optimizes your engine’s ignition timing, torque converter lockup, and shift point settings - maximizing fuel economy by reducing engine rpm and permitting the use of less-expensive lower-octane fuel.
Whether you’re looking for faster acceleration, better towing performance, or optimum fuel economy, the FAST-FLASH™ Power Programmer delivers performance without compromise.
Change top speed limiter
Transmission shift firmness
Transmission shift points
Engine rev limiter
Cooling fan on/off temperatures
Correct the speedo for bigger wheel and tire sizes
50 state emissions legal
Old Nov 29, 2008 | 09:37 PM
DKITCHEN's Avatar
Answered pm's. To the top!
Old Dec 3, 2008 | 01:35 PM
DKITCHEN's Avatar
Bump!
Old Dec 3, 2008 | 02:42 PM
FiFdYnUtz's Avatar
so can i adjust my AF ratio with this?
BlackMafia's Avatar
I think you should do your good deed for the year and give it to a long time friend like me as a Christmas gift and let's leave the Cowboys and Deadskins or as you would Cowgirls and Redskins........out of this conversation
Old Dec 4, 2008 | 06:30 PM
lilpb1's Avatar
Would it work on a 2000 camaro?
Old Dec 4, 2008 | 09:31 PM
lilpb1's Avatar
PM sent!!!
Old Dec 5, 2008 | 11:23 AM
slikka1202's Avatar
pm sent can pick up this weekend!!!
Old Dec 5, 2008 | 04:32 PM
DKITCHEN's Avatar
Didn't think you were in the market for new parts Frank! I'm still trying to get my Brother in law to buy your beast. I think he's a permanent window shopper! Already sold the programmer to a non cowboy fan
