TSP 418ci Shortblock (24x) Located in KY
Looking to sell my Texas Speed 418 Shortblock, Its located in Nicholasville KY so if you are anywhere within driving distance of me you can save yourself the$430 I paid on shipping. I am asking $3500 for the shortblock which is $675 less than they sell for at TSP. I will even include the engine stand its on. Engine is Brand New, never installed in the car and has a 24x reluctor wheel on the crank so its a direct bolt in for the LS1 F-Bodys.
Engine Specs:
GM L92 Aluminum Block
Eagle 4.00 Stroker Crank
Eagle 6.125 H-Beam Connectin Rods w/upgraded ARP 2000 Bolts
Diamond Racing 418 Stroker Piston Set 4.080 Bore Flat Top with -4cc VR
TSP Total Seal Ring Set 4.080 +.005, 1.5mm Plasma Moly Top, 1.5mm Napier 2nd, 3mm Oil.
Clevite Rod and Main Bearings
LS2 Camshaft Bearings
GM Oil restrictor installed
GM oil Galley plug
GM Coolant Plugs
Assembly by TSP
Block work: Vat Block, Line Bore, Install new Cam bearings, Bore and Hone with Torque Plate, Balance Rotating assembly, Line Hone.
To buy this exact same set up from TSP right now you will pay $4175.00 with the upgraded ARP 2000 Rod Bolts. Plus shipping which ran me $430.00.
http://texas-speed.com/shop/item.asp...d=686&catid=20
Engine Specs:
GM oil Galley plug
GM Coolant Plugs
Assembly by TSP
I was going to run it N/A and add the bottle later.
These are the pistons in it, I believe they would handle a decent shot of Nitrous but they are Flat Top style Pistins and not dished so I would say you would be limited on the amount of Boost you could run depending on which heads you ran.
http://www.texas-speed.com/shop/item...d=787&catid=38
I will also include the front cover with sensor, rear cover and valley cover with Lifter Trays, cam retainer plate, and Katech Knock sensor and cam sensor adpater harness for $3800 as a package deal.
