LS1 Parts (Little of Everything)
Had a few different ads going that I wanted to consolidate so here goes with lower prices.
Windage Tray with Nuts $SOLD!!!!!!
Rear Cover with Bolts and Gaskets SOLD!!!!
Cam Plate with Bolts $15 Shipped
LS2 Lifter Trays with Bolts. SOLD!!!
Timing Chain Damper $20 shipped
LS1 Motor Mounts with New prothane Bushings SOLD!!!
LS1 Valve Covers with Bolts, Gaskets, grommets, Cap. $100 shipped
LS1 Water Pump with Thermostat.SOLD!!!
New GM Map sensor # 16212460 $40 shipped.
New Intake Bolts for LS1/LS2/LS6/L76 with Fule rail Bolts, Injector Clips and Misc Brackets. SOLD!!!!
LS1 Brake Backing Plates (New from GM) $160 Shipped
LS1 Front Calipers and Brackets. SOLD!!!
LS1 Rear Calipers and Brackets $100 Shipped(Low Mileage)
LS1 Brake Booster 50k Car but needs cleaned up due to leaky Master. $30 shipped
PST Aluminum Driveshaft 1350 U-Joint 1" Longer for 9" rear. 1k miles. SOLD!!!
LS1 Bellhousing SOLD!!!!!
LS1 Slave from 02 WS6. 24k Miles, was removed when doing a clutch swap and is in working condition. SOLD!!!
Idler/Tensioner Assembly with Bolts. SOLD!!!
Comp cams 7.4 PushRods(New in Sealed Box) Part# 7955-16 $SOLD!!!
