'94 Z28 with LS1/Auto swap ... need to sell ASAP
I had this car for sale a couple months ago but it needed some work then. Meanwhile, I decided to keep it; so I worked on it and fixed almost all the known issues (brake booster, rebuilt the trans, etc., wheels/tires, etc.). But now it turns out I can't keep it "and" the T/A 'cos we're having a baby (due in May) on the ways so I need to sell. I'm asking $4250 o.b.o., BUT If I can sell before the 23rd of Dec. I'm willing to let it go for $3500 as is, I'm leaving for vacation after that and will only be back Jan 14th, at which point I can take my time and fix the rest and probably get more if I can ... Even then, money talks!!! Here's the rundown ... All this has only about 10 miles max after the mutt motor was installed (it used to have a 6.0ltr setup that's in my T/A now).
Powertrain (LS1 Conversion):
Take off '99 block with about 100K miles (no issues and was used well, I knew the past owner).
'98 heads/intake/etc.
'98 fuel lines/etc.
'98 PCM/Engine harness modified (by myself) to plug-n-play with LT1 body harness.
Stock '98 Cam/valvetrain.
K&N FIPK Cold air kit with extra large filter (the one with the kit fell off so I bought a bigger/longer one).
Mid-length headers (y-pipe with cats has been welded to the headers).
Catback from a '01 WS6.
Racetronics in tank pump and modified hotwire harness.
Hotchkis LCA's.
Chameleon head Unit, 300Watt amp and Kenwood 12" Sub.
Line lock.
LS1 front brakes.
3.42:1 gears
Rebuilt 4L60E Trans with stock stall (has only about 5 miles on the build, all it took to get her home).
Body/etc.:
New front bumper cover (new paint on hood and fenders)
Hood clear coat is peeling
Body is straight and has no major flaws and was never in any wrecks/etc. and is typical of a car this age.
16" Firebird ABS rims with brand new 16" tires
Needs/bad:
Water pump squeaks
I think the header gaskets may have a slight leak.
A/C was never installed with the swap.
Dash pad is cracked (aren't they all?).
A few Misc. holes where gauges/switches used to be.
Driver window motor is bad.
Needs alignment and maybe brake pads to pass inspection.
Also has a Black Widow remote start/alarm system with pager installed but I can't get it to work, I'll give you all the wiring diagrams that BestBuy gave me ('cos I asked for them) and I know it's only a couple wires that need to be reconnected.
I cleaned and shampoo'd the interior today and it's "oh so clean" !!! ... lol
These pics aren't the latest. Externally, the only difference is the wheels/tires.
'98 fuel lines/etc.
Hotchkis LCA's.
Line lock.
LS1 front brakes.
3.42:1 gears
Body/etc.:
Needs/bad:
Water pump squeaks
UP ... seriously wanting to make a sale so if you're serious and even a bit short on my asking price, PM me and I'm sure we can work something out. Will accept partial trades, here's what I'm looking for...
GOOD stereo system with screen/DVD/Navi/etc. head unit.
GOOD amp/s with wiring <-- got a set so that's out of the list
Q logic dual Sub Box that puts the subs where the little flap is.
12bolt/9"/Dana rear with pref. 3.73s or 4.10's
Big Brake Kit in GOOD condition
A nice set of wheels/tires like Fiske's
A turbo kit to work on my '98 T/A
OR ... I'm looking for a motorcycle (pref. cruiser)
I'm just not looking for another car right now ... we have 5 cars parked in my driveway right now ... ughhh
