LT1 Parts CLEARANCE!!
PRICES LOWERED AGAIN! THIS STUFF HAS TO GO, CAN'T AFFORD TO STORE IT AND NEED THE MONEY FOR A REBUILD. MAKE ME AN OFFER, I NEED IT GONE!!
Paypal is preferred.
Pics of almost everything are here: photobucket
Engine and Exterior Parts:
New 93-94/95 Opti connector pigtail $61 new $16 shipped
Driver side Headlight Motor, wiring, clips, (gears grind a little) $40 shipped
Suspension, Brakes, Air Bags and other parts:
Stock LT1 Front sway bar $30 Shipped
Stock Front springs $30 shipped
Power rack & pinion $45 shipped
EBCM $25 Shipped
Driver Airbag $25 shipped
Passenger air bag $55 shipped
Air Bag SIR Computer, SIR coil, all sensors and wiring. $35 shipped
Interior Items and Parts:
HVAC controls $20 shipped
Door panels with tweeters (Grey) $110 shipped for Both.
Dome light assembly $15 shipped
EBCM $25 Shipped
94-02 LT1/LS1 Fast Toys Ported MAF Ends
Increase the performance of your engine with Fast Toys ported MAF ends! These high flow components replace the restrictive factory aluminum inner and outter MAF ends. Working in conjunction with your factory MAF electronic sensor, our MAF ends increase airflow potential to over 1000 CFM!
Just look at the picture comparing the factory aluminum MAF end to our high flow design! The difference is obvious.
Featuring a composite plastic construction, these ported MAF ends remove the restrictive center dividers and screen that are present in the factory design. In addition, our MAF ends will not heat soak which is a common problem with the factory aluminum design. Cooler air equals more power!
Unlike other brands, these shells are formed in one piece molds which mean that the inside of the shells are smooth for the best possible airflow. On our 1998 LS1 Camaro test vehicle, the ported MAF ends were worth a solid one MPH in the quarter mile!
just looked up the cost of a "new" remanufactured started on summit and autozone and realized after spending $15-$20 to ship it to someone, I'm better off just finding a place under the bed for it then get $10 for it and eventually have to spend $140-$170+ for another one. Starter no longer for sale, sorry about that guys.
I'll take the optisensor pigtail if you still have it email me at shoeboxchevy@hotmail.com
Thanks,
Richard
Thanks,
Richard
