F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e
Old Dec 17, 2008 | 09:46 PM
NightKid#2's Avatar
Default F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e
EVERYTHING SOLD!!
PLEASE read what’s included before asking me if it is or not.
I have listed all parts you will need to have a fully running engine also.
Engine Parts
The wiring harness was modified by me(3rd time I’ve done this) and is now a fully stand alone harness, all unnecessary wires have been removed. All hook-up wires are fully label for an easy install. Also has wires installed for aftermarket oil pressure and water temp gauges. Will neatly wrap after sell.
I can, for the buyer:
Delete A/C and all wires associated.
Turn the harness into an “Automatic Transmission” harness
Computer, per buyer’s request:
Remove VATS
Remove rear O2s
Set “on” fan temp
Retune computer for an automatic
I am looking to get my moneys worth for this set-up/time and parts put into it
And also a local buyer – I will start my price at $1700 obo
Any OTHER question anyone needs answering, there is PM’s and my cell at 281-413-4582
I am located in Cypress TX 77429
Shipping: Can/Will Ship at buyers expense, Send me a zip and all send you a quote. Well be shipped with the oil pan in the picture but it is in no way usable.
Will separate if I have a buyer for each/every thing.
Included:
2000 engine block w/ 86k from a Firebird Formula
Installed 2002 241 vette heads with valve job, new seals, installed with all new bolts and metal head gaskets
2000 modified wiring harness
2000 stock computer (currently for manual trans)
2002 Low mile 18K stock springs and rockers
Installed New GM high performance lifters
New LS2 water pump with gaskets
Installed New LS6 oil pump
Installed New LS2 timing sprockets and chain
Starter
Stock balancer pulley
Valve covers
Alt bracket
A/C bracket
P/S pump bracket
Oil pickup tube and tray
Coil packs and brackets
Stock spark plug wires
NGK TR55 Spark plugs
Stock Fuel lines
Stock Injectors
LS1 intake
LS1 Steam crossover pipe
LS1 Throttle body and sensors
Two O2 sensors
EGR block off plate
Cam, thermostat, oil level sensors
Bolts bolt bolts
All the parts you will need to make it run:
Pushrods
Oil pan
Alternator
P/S pump, A/C compressor
The converter: IS SOLD
Other Parts I can also provide:
3" in/out flowmaster y pipe
Dynomax welded race muffler 3" in/out
Cheers, JR
Attached Thumbnails F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-engine-side.jpg   F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-parts.jpg   F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-harness.jpg   F/S 2000 LS1 engine/PCM/harness, yank SS 3600 4l60e-1101071225a.jpg
Old Dec 17, 2008 | 09:47 PM
NightKid#2's Avatar
Converters SOLD!!
Old Dec 17, 2008 | 10:12 PM
venom99's Avatar
want to seel just the engine harness
Old Dec 18, 2008 | 12:06 PM
NightKid#2's Avatar
Not at the moment, sorry.
Old Dec 18, 2008 | 10:23 PM
eric1h's Avatar
very interested, give me a price shipped to 27560
Old Dec 19, 2008 | 05:38 PM
eric1h's Avatar
deposit sent :-D
Old Dec 19, 2008 | 05:47 PM
dcazin's Avatar
boo ya!
Old Dec 31, 2008 | 08:42 PM
eric1h's Avatar
knock knock, any update on when this is ready to ship?
Old Aug 30, 2009 | 02:09 PM
realslow94z28's Avatar
do you still have coil packs
