A bunch of LSx stuff for sale
Shipping is free to anywhere in the continental US. All items are available for local pickup also, all are in Lake Zurich, IL. I will be adding some more parts as i find them. you can PM me or email at
Complete Vortech aftercooler system for the Vortech superchargers for LS1/6 motors.
This kit allows you to run 9 to 10 punds of boost safely. When I bought this it was originally the as cast version, no finish. I polished the entire system before bead blasting the system. It is bead blasted to a very fine satin sheen and then clear coated. It looks awesome, especially in the sun. The aluminum parts are absolutely smooth, no bumps at all. If you wanted to polishe this again, it would be very easy to do.
The only thing missing are two of the rubber pipe couplers. These are cheap and easy to buy though. The cooler, the piping and the coolant fill tank are all finished and clearcoated. For the whole sytem, all fittings are installed correctly where they go and are water tight. There are pictures below, they should give you a good idea of the finish.
Included is all you see in the pictures .There is a little groove on part of the aftercooler where my hood rubbbed on it. You won't really notice it very much.
$800
Racetronix wiring harness for 99-02 F-Bodies.
Brand new, never used, still in the original bag. Very nice work, this thing is put together very nicely. The package contains the items below:
• F99-FPWH Wiring Harness
• BGK8 Battery Ground Upgrade Kit
• PBIC Pump Booster Connector Set
Some of the features:
• Plug & Play (no soldering or crimping required)
• Weatherproof Delphi connectors
• Heavy 10 Gauge stranded copper wire
• Tyco 40A waterproof silver-contact relay
• Alternator-direct hookup for maximum performance
• Silicon grease, spare fuse, wire ties included
• Compatible with MSD or KB pump boosters
• 8Ga. body ground upgrade w/ brass battery nuts
$70
Fuel Pump Racetronix Walbro 340 for 99-02 F-Bodies with a plastic tank
The pump was built by Racetronix, it occupies the stock fuel bucket. Most internal components were upgraded, along with the fuel sock. It was used for 30 miles, at half throttle. It is in like mint condition. It is ready to run, just drop it in the tank, hook it up and go.
$100
$800
$70
$100
