LS6 intake, Convo Pros, BMR LCA's
Up for sale
LS6 Intake Part # 12573572, Has EGR Hole but i currently have a plug in it that can be removed if required. Only Issue with it is the front bolt that holds the fuel rail down on the passenger side, broke, so it would need to be drilled and removed. Asking $280 Shipped
Pics
Front Set Of Convo Pro Skinnies, Dual Bolt Pattern 5x4.75 5x4.5, . This is for the Rims Only! Tires will be removed before shipping. Rims will shine right up with a quick polish. Not sure on the backspacing but they bolted right up on my camaro and didnt rub at all on the calipers and they didnt stick out either. Only real issue with them is the previous owner used the factory lugs on them, which kinda dented the hole where the lugs go a slight bit. Asking $200 + 1/2 Of Shipping Cost.
Pics
Thanks!
Pics
Pics
Thanks!
