6-spd Conversion, Built T-56, Spec Clutch, Pro 5.0 shifter, everything need for swap
Old Jan 3, 2009 | 01:01 PM
CalSpeedPerformance's Avatar
Default 6-spd Conversion, Built T-56, Spec Clutch, Pro 5.0 shifter, everything need for swap
SOLD
Complete 6-spd conversion, was all done 4500 miles ago. Swapping to th400 in my 00 SS. All of it in great shape, you can come drive the car if you are local. This is everything you should need to swap to a 6-spd in your
Anaheim Gear built M6 T56 with upgraded synchronizer keys, steel 3-4 shifter fork, hand fit sliders & hubs, blocking rings.
Spec Stg 3 Clutch & Flywheel Assembly, Pro 5.0 Billet shifter
Complete master/slave hydraulics/lines, bellhousing etc
Transmission Crossmember with transmission mount
6-spd Torque Arm mount
6-spd center console center piece / boot / shifter **** etc
6-spd clutch pedal assembly.
also included if needed - Complete 99-02 Engine Wiring Harness with 6-spd transmission connection (WITH SWAP/EXCHANGE OF YOUR 99-02 A4 engine wiring HARNESS ). You can just unplug and remove your whole harness and plug the 6-spd harness in, no cutting/rewiring needed.
I can also include a tuned 6-spd PCM computer in exchange for your PCM.
All of this will just directly bolt into your A4 auto car and be everything you need to directly swap over with a factory fit/finish setup.
Old Jan 3, 2009 | 09:19 PM
ls6_rx7's Avatar
bit out of my price range however i was wondering if you knew of any others for sale?
Old Jan 3, 2009 | 09:20 PM
Stock T56 conversions similar would probably go for 500-750 less...
Old Jan 4, 2009 | 03:21 AM
Actually I think the price is a bit low.
Factor $150 of it in shipping. Including the core of a T56 transmission, youve got well over $2k alone in doing a built T56 with all the good parts in it. Then factor another $1500+ in additional parts included.
Stock complete T56 setups such as this sell for over $2k plus shipping on ebay (I just sold one from a wrecked car for $2200 plus $150 ship couple weeks ago). Any person wanting to do a good setup will spend the different in just the clutch/shifter alone and this has a built T56 transmission.
Old Jan 4, 2009 | 04:51 PM
tttttt
Old Jan 4, 2009 | 09:35 PM
ls6_rx7's Avatar
hardly.. stock ones are going for 1300-1700 depending on milage and condition. Obviouslly not for rebuilt and upgraded ones like this tranny setup. This is a good deal for someone who is looking for all that.
Old Jan 4, 2009 | 10:14 PM
boydcoz71's Avatar
would you be intersted in trading for a 800rwhp th350 set up ?
Old Jan 6, 2009 | 02:00 AM
sorry not looking for a th350
Old Jan 6, 2009 | 03:52 PM
jpajkos's Avatar
Where in so cal are you located? Please email me at jessiep916@live.com thanks
Old Jan 6, 2009 | 07:40 PM
Located in Shafter, CA (10 minutes north of bakersfield)
Old Jan 6, 2009 | 08:32 PM
Zman89's Avatar
PM sent
Old Jan 7, 2009 | 04:29 PM
Soldd
