FS: DiabloSport Predator Flash Tuner U7191
Old Jan 6, 2009 | 12:30 PM
EmersonHart13's Avatar
Lightbulb FS: DiabloSport Predator Flash Tuner U7191
This is a used and unlocked DiabloSport Predator Flash Tuner that I was using on my 06 GXP. It includes the power adapter and serial cable. (If you need a USB to Serial Adapter I can include that for a few extra dollars) The newest version of the PC software can be downloaded off their website so that will not be included. Pictures are available upon request. (It looks the same as the website minus a few scratches)
I am looking for 200 + Shipping... Please post with any additional questions or offers!
Thanks,
John
Here is the description from their website:
This tuner is an awesome addition to your LSx. It comes with a DiabloSport performance tunes, and also allows you to tweak and fine tune other settings, such as removeing the skip shift feature in many GM manual vehicles. This tuner also turns off the speed limiter on the GTO when you install Diablosport's performance tunes.
U7191 Predator Applications:
GTO - LS2 - 2005-2006
Corvette C6 - LS2 - 2005
SSR - LS2 - 2005-2006
Trailblazer SS - LS2 - 2006
Pontiac GXP - LS4 - 2006
Monte Carlo SS - LS4 - 2006
Impala SS - LS4 - 2006
U7191 Stock Vehicle Tunes:
* Performance Tune: Designed to add power and torque using premium fuel.
* 91 Octane Performance Tune: Designed to add power and torque using 91 octane fuel.
* Performance No DoD Tune: Designed to add power and torque using premium fuel with DoD disabled(for vehicles with DoD).
* Performance 91 oct No DoD Tune: Designed to add power and torque using 91 octane fuel with DoD disabled(for vehicles with DoD).
* Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
U7191 Specific Features:
* Click here to see more details on how to adjust parameters.
* Timing Table 1000-1800rpm (+15/- 40%)
* Timing Table 2000-3800rpm (+15/- 40%)
* Timing Table 4000-7000rpm (+15/- 40%)
* Fuel Table 2000-3800rpm (+/- 20%)
* Fuel Table 4000-7000rpm (+/- 20%)
* Idle (+ 400rpm / -400rpm)
* Rev Limiters
* CAGS ON/OFF (skip shift)
* COT ON/OFF (catalytic converter overtemp protection)
* COT enable time
* Fan Calibration
* Adjust for different injector size
* Internet Updateable
* All standard DiabloSport Predator features
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
Average power gains are per tune. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
Old Jan 6, 2009 | 04:07 PM
sickREDsierra's Avatar
finally moving to a custom/dyno tune huh.
good move Mane.
Old Jan 6, 2009 | 07:57 PM
Nope, don't know what I am doing, but this hasn't been installed on the car since fall due to some warranty issues and thinking I might just go back to stock...
Old Jan 20, 2009 | 11:52 AM
SOLD!
Thanks.
