FS: LS4 Hogan Downpipe w/ Cat and Interlock Flex
Old Jan 6, 2009 | 01:39 PM
EmersonHart13's Avatar
Default FS: LS4 Hogan Downpipe w/ Cat and Interlock Flex
Model: DP7S 409 Stainless Steel
This item is in used but like new condition. It only saw one summer and fall of use. I am looking for 175 + Shipping and pictures are available upon request.
Thanks,
John
Here is from the manufacturer's website:
This is our top of the line down pipe and converter assembly for 05-06 V-8 GXP and 06 V-8 Impala SS and 06 Monte Carlo SS. This unit incorporates our exclusive machined upper flange, free flowing 3” 409 Stainless Steel mandrel bent down pipe with a new Magnaflow high flow converter and a 3” outlet pipe (outlet pipe is reduced to 2.5” at rear flange to allow connection with factory or aftermarket Cat Back Systems) O2 sensor bung and hanger included. Remove 4 bolts and your old converter and this unit bolts right in place!
Key Benefits
409 Stainless Steel mandrel bent tubing
Stainless steel flex coupler
Custom made heavy steel flanges front and rear
True bolt on with hand tools
Magnaflow Super Hi Flow Catalytic Converter
Note: We have had a few recent reports of a PO420 code setting a check engine light with this item. This has not been a reoccurring issue but we thought it best to inform you of the possibility. Hogan Performance will not warranty this item due to this code. There are several companies who offer computer reprogramming or computer tuner to eliminate this issue.
Old Jan 8, 2009 | 10:37 AM
LS4SPEED's Avatar
sending PM now!
Old Jan 20, 2009 | 11:55 AM
SOLD!
Thanks!
