SUPER SALE on RAPTOR SHIFT LIGHTS @ KY SPEED
Sale on all Raptor Single and Dual Mode Shift Lights:
PM for pricing as it is too low to advertise
Raptor Dual Mode Shift Light with Launch Feature
Make your launch consistent with the aid of a Raptor dual mode launch/shift light! Our newest edition of shift lights for 2008, incorporates a launch feature as well as the features in our standard shift light. This model allows the user to set a desired launch rpm, upper and lower launch limits, pulse/rev, and shift point setting. Stand alone operation!
Uses the signal to the speedometer or the Vehicle Speed Sensor Signal to determine launch or shift mode.
Example: Program the launch to 3000 rpm, +/- 200 rpm and shift point at 6200 rpm. This effectively creates a launch "window" of 2800 rpm to 3200 rpm. If the vehicle is staged (not moving) the unit enters into launch mode automatically. If the rpm is under the lower limit of 2800 rpm, the LEDs are off. If the rpm is above 3200 rpm, the LEDs flash rapidly. However, if the rpm is within 2800 rpm and 3200 rpm, the LEDs are on constant. So the user simply brings the engine rpm up until all LEDs are on. This keeps one from looking down at the tach trying to keep the tach needle to the desired launch point. After the launch, the unit automatically disables the launch mode and enables the shift mode, where it will come on at 6200 rpm in this example.
If you choose to not use the launch feature when your not at the track, simply press the program button twice within one sec to disable the launch feature. When your ready to race again, simply press the program button twice within one sec to re-enable the launch feature.
Available in four LED colors. Seven bright LEDs visible in direct sunlight. Easy wire-up: 4 wire connection. With the supplied ten foot long black cable, you don't need to add extra wiring.
RISC processor for extreme precision and easy user interface. Simply press and hold the program button to enter into program mode, where you can set the desired launch rpm, launch limits and shift point setting. The new settings are then stored in memory. Program mode 2 allows you to set the pulse/rev, etc.
Dimensions: 3.625" long x 0.75" diameter. The most compact shift light of any manufacturer! Allows you to mount it virtually anywhere within the vehicle, even in the AC vent for a hidden but effective shifting tool.
Two different style Mounting Brackets. Vinyl covers are for reducing emitted light intensity for night racing. They do not determine the color of the emitted LED light. Covers match the LED color.
**Note** Will not work on cable driven speedometers!
Raptor Digital Mini Shift Light
With the help of a Raptor shift light, you don't need to worry about missing a shift. You will get consistent results, shifting at the exact desired engine RPM each and every time. With the aid of a Raptor shift light, hitting the rev limiter while going down the track is a thing of the past!
Available in four LED colors. Seven bright LEDs visible in direct sunlight. Easy wire-up: power, ground and tach signal. With the supplied ten foot long black cable, you don't need to add extra wiring.
Available in four color anodized, 6061-T6 aluminum housings for extreme durability. Also available in chromed aluminum housings.
RISC processor for extreme precision and easy user interface. Simply turn the two rotary RPM switches for the desired setting, select the cylinder setting to match your vehicle and cycle the power. The new settings are then stored in memory.
Dimensions: 3.125" long x 0.75" diameter. The most compact shift light of any manufacturer! Allows you to mount it virtually anywhere within the vehicle, even in the AC vent for a hidden but effective shifting tool.
Iwas just getting ready to order one.
