Moser 12-bolt
SOLD!!!!
Going a different route with the new rear end. So I'm selling this by itself now. $2000 takes it.
Moser 12-bolt
Full spool
new Richmond 3.73's
new ARP wheel studs
33 spline axles
T/A Performance cover
UMI LCA relocation brackets welded on
stock width
4 channel, but will work with 3 channel cars if you don't mind losing your ABS.
I'll also throw in a set of Richmond 4.11 Pro Gears ($300 new) for an extra $150.
Moser 12-bolt
Full spool
new Richmond 3.73's
new ARP wheel studs
33 spline axles
stock width
Probably about 5k miles on the rear-end. The axles were out two weeks ago when I put the new wheel studs on, and they still look new. The spool and gears are new. It's a 4-channel, which I believe (someone correct me if I'm wrong) accomidates ABS and TCS. My car is a 3-channel, no TCS, so with this rear-end in my car I had to ditch the ABS. It whines a little bit....has since it was new, but 12-bolts are known for making a little noise...nothing unusual, and I've never had any issues. No burnt fluid has ever come out of it, no gears have ever broke, no seals have ever leaked. I'm in NC, 28390.
With the spool, 33 spline axles, and T/A cover it can take quite a bit. If you put the Pro Gears back in it it will be able to take even more. This rear-end also already has the "good" crush sleeve as well. I run low 10's all day with no issues at all, and wouldn't think twice about running low 9's with it the way it is.
So, I had made arrangements with ^^^^^ MusTangKilla01Z28. ^^^^^ I was still running this car, and wanted to wait until it sold to take it out of the car. Friday, MusTangKilla01Z28 and I made the deal, and he was to pick the rear-end up tonight. So I had the Wolfe anti-roll bar cut off, and took the rear-end out today, only for him to ignore my calls and not show up. Be a ******* man and at least tell me you're broke, or you can't pick the **** up. Ignoring phone calls is a bitch move.
Anyway, the rear-end is out of the car and back up for sale. $1900 picked up, or $1900 PLUS SHIPPING. I will not go any lower than $1900, so don't ask. It's bad enough that I can't run anymore because this la douche decided to bitch out and not let me know about it.
02ss ok man.... be an *** whole as if its any of your bisness but i have been in the hospital WITHOUT signal beacuse of some drunk teenanger hit my little brother on his way home! and yes i do have the money and yes i still planed on getting it! but its whatever man.... thanks for the raiting GL with the sale!
ttmft...
WOW!!! some people!!!hahaha
You dont know how much it would cost to ship huh? Im in Louisiana.
Im DIEING to get a moser and this is a GREAT PRICE i have the $$$$$cash but i only have a limited amount, so once i do shipping and install it may just be smarter to buy local....any thoughts??
if youd like to give me a call my number is 337.207.2519.
Just a suggestion on the axle shipping....I just quoted 123.33 for a 12 bolt shipped on a pallet (est weight of 275) from arizona to arkansas...
Try freightquote.com
Also this was axle dropped off at a terminal and picked up at a terminal,,much cheaper
PM sent dude. Let me know.
What freight class did you qualify for when you used freightquote.com? I put the weight and dimentions in on the website, and it put me in the 70 class, quoting me at $114 if I dropped it off at the terminal. 5 minutes later, I get a call from freightquote, and the dude takes some info and then tries to tell me it would be a freight class 250, and cost $390....which is when I told him where to stick it.
