FS: TSP 224R Comp Cam
Old Feb 18, 2009 | 05:30 PM
darknessxyz's Avatar
Default FS: TSP 224R Comp Cam
Selling my 224R cuz I bought another cam. 224/224 .581/.581 112 LSA. It has about 2k miles on it with stock head. No issue or nick or any mark on the cam. $250 shipped
Old Feb 18, 2009 | 06:01 PM
SimZ28's Avatar
So this will work with no other mods? How much power did it make?
Old Feb 18, 2009 | 08:05 PM
It's the so-called baby cam. I know some guy run it without anyother mod. I never dyno this cam but decent low-mid range power. It's a very streetable cam and not too choppy or loud.
Old Feb 19, 2009 | 01:43 AM
Hashish's Avatar
Im kind of a newb. Does this need new valve springs??
Old Feb 19, 2009 | 02:01 AM
Yes, you'll need now valve spring for this. However, any single valve spring with .600 lift will work ie, Comp Cam 918 spring.
Old Feb 19, 2009 | 02:04 AM
SSmokin99's Avatar
Why did you get a 224/224 112LSA cam if you had this one? Also, is the new one you bought a TR?
Old Feb 19, 2009 | 04:48 AM
I bought another one here used, custom comp cam grind. So this one needs to go.
Old Feb 19, 2009 | 01:45 PM
efren80's Avatar
pm sent...
Old Feb 19, 2009 | 02:09 PM
eddielb's Avatar
what kinda power does this make? and how much are the things needed to support it? (springs, lifters? pushrods?)
thanks bud !
Old Feb 19, 2009 | 04:32 PM
thanks bud !
I never dyno this. My guess will be around 370rwhp with LS6 intake and ported TB, don't quote me tho.
You'll need .600 lift valve spring that's for sure, Comp Cam 918 will work. Lifters and pushrod is a piece of mind, since you tear down everything might as well replace them if you've higher mileage. Also you'll need a cam install kit which included all the necessary seal, gasket and bolt. That's about it.
Old Feb 20, 2009 | 03:11 PM
taking reasonable offer.
Old Feb 20, 2009 | 04:04 PM
eddielb's Avatar
got a link to cam install kit, trying to piece how much everything is going to cost me... i am very very interested though
Old Feb 20, 2009 | 04:22 PM
Here you go at Texas Speed:
http://www.Texas-Speed.com/shop/item...id=85&catid=36
You can also order your valve spring over there. Your best bet is call Texas Speed and ask them what's your basic need to install this cam. I think you might need a LS6 oil pump as well.
Old Feb 21, 2009 | 01:37 PM
Tony 2000's Avatar
how bout 200 shipped
Old Feb 21, 2009 | 01:39 PM
Send you a PM
Old Feb 21, 2009 | 11:57 PM
SS#1230's Avatar
will my LS6 (05 CTS-V) springs work with this cam?
im interested. oh, do you know if it will pass california smog?
Old Feb 22, 2009 | 12:21 AM
The yellow spring will not work. They only lift at .550 while this cam lift at .581. At high rpm WOT, the valve will float. At least you need Comp Cam 918 or any valve spring lift with .600 so the valve will open and close on time.
This cam will pass CA smog sniffer test no problem. I can almost guarantee you that cuz my friend run 224/228 and pass smog no problem. He run both cat of course. No way any car will pass sniffer test without cat.
Old Feb 22, 2009 | 02:08 AM
STROKETHIS1's Avatar
so is this a comp cam or thunder racing???
Old Feb 22, 2009 | 02:59 AM
This is a Comp Cam from Texas Speed Performance and the title said it's a Comp Cam already. Please read.
Old Feb 23, 2009 | 11:09 PM
Bump. Antone need this cam?
