*HKE 416 LS3 Shortblock, Greg Good LS3 Heads, & Performance/Stock Part Out Sale!*
Old Mar 14, 2009 | 01:50 PM
Dragaholic's Avatar
9 Second Club NA
Default *HKE 416 LS3 Shortblock, Greg Good LS3 Heads, & Performance/Stock Part Out Sale!*
Below is a list of the available parts for sale. If you do not see what you're looking for, I do not have it. Please do not ask me about parts not listed below.
Condition of parts: If there's an asterik (*) next to the part, it means that it's practically new with only (10) 1/4 mile passes on it. The rest of the parts are in excellent/new like condition.
Feedback: I have 100% positive feedback here on the board and on Ebay (i8asvt), with a combined score count of 184.
Payment: I accept Paypal, money orders, cashier's checks, Western Union, Moneygram, etc., with Paypal being the preferred payment. If you choose to use Paypal for payment, you must send as an instant transfer or an e-Check. No credit card payments. You must select the Personal tab and choose Payment owed or Other for "This money is being sent as a:". If you choose the Purchase tab, then 2.9% + $.30 will be deducted from the money I received and I will not be responsible for those fees. If you wish to choose the purchase tab, then you will need to add the 2.9% + $.30 fee to the amount owed on the purchased item(s).
Shipping: Prices do not include shipping unless specified.
Prices: No low balling, trades, bashing, and please, do not reference prices to Ebay. If you have any comments, opinions, or suggestions, please PM me. There's no need for a discussion, debate, or war on my parts for sale. So please, let's keep this clean.
Engine:
*GM LS3/L92 Aluminum Block
*Callies Dragonslayer 4” Stroke Crankshaft
*Callies Connecting Rods
*Wiseco Custom 9.6cc Dome Pistons
*Wiseco Custom Pins
*Wiseco GF Piston Rings
*Federal Mogul Main Bearings
*Federal Mogul Cam Bearings
*ACL HB Coated Rod Bearings
*ARP Main Stud Kit
*ARP 2000 Series Rod Bolts
416 CI
Shortblock: Block honed, line honed, deck set with pistons, balanced, and assembled by Erik Koenig of HKE Racing Engines - $4,925
Cylinder Heads/Valvetrain:
*Greg Good Fully Ported/Polished LS3/L92 Cylinder Heads (New Castings) w/Xceldyne Titanium Intake Valves, Ferrea Hollow Stem Exhaust Valves, Custom Spring Seats, Patriot Gold Extreme Dual Spring Kit, & 67cc Combustion Chambers - $2975
*Manton Restricted Pushrods - $170
Intake:
Fast Toys Ram Air Block-Off Plate -
Forced Induction:
Procharger Open Race Bypass Valve - $325
Exhaust:
Kooks 3"x3" Catted X-Pipe ('97-'09 Corvette) - $600
Ignition/Electrical:
O2 Extensions (1) 12" (1) 24" - $20 each
Drivetrain/Transmission:
Protorque Torque Converter (TH350) - $850
Suspension & Chassis:
Wolfe Racecraft Sway/Anti-Roll Drag Bar (Black) - $300
Interior & Safety:
*Autometer Ultimate II Tachometer $525
Wheels & Tires:
*Hoosier Radial Slicks 30x10.5x15 - $390
McGard Front & Rear Lugnuts - $85
Bogart Center Caps -
(1) 275/35/18 Dunlop SP Sport 01 (25% left) - $20
Stock Parts:
A/C Condenser - $100 shipped
HVAC Ducting (for vents) - $20 shipped
Brake Master Cylinder - $80 shipped
Brake Booster - $100 shipped
Rear Brake Rotors - $50 shipped
Rear Brake Hoses - $35 shipped
Front Brake Hoses -
Brake Lines (engine bay area) -
Wheel Hubs w/Speed Sensors - $200
Air Pump Bracket - $15 shipped
Lifters - $60 shipped
Intake & Exhaust Valves -
Monsoon Amp - $80 shipped
Triangle Hold Downs (hatch area) -
Passenger Airbag Bracket - $15 shipped
Rear End/Swaybar U-Bolts/Brackets -
Panhard Bar - $30 shipped
Rear Coil Springs -
Upper A-Arms - $70 shipped
Upper A-Arm Brackets -
Upper A-Arm Mounts -
Spindles -
Rear Swaybar Bushing Bracket -
Wiper Motor/Linkage - $90 shipped
Wiper Arm Covers -
Rear Bumper Support - $75 shipped
Front Air Dam/Spoiler -
*Valley Cover Gasket - $20
*Rear Cover Gasket - $20
*Timing Cover Gasket - $20
Oil Pan Gasket - $30
Motor Mounts -
Fuel Hoses/Lines (engine bay area) -
Brake Booster Hose w/Fitting -
Fuel Purge Solenoid -
Napa Belt 76" 6 Rib -
Napa Belt 37.8" 4 Rib -
Air Lid Seal -
Old Mar 16, 2009 | 02:41 PM
Chris'stransam's Avatar
is it built for nitrous/boost ?
Old Mar 16, 2009 | 09:41 PM
Dragaholic's Avatar
9 Second Club NA
Definitely not boost, but if I recall correctly, Erik may have mentioned that nitrous can be used. As far as how much, I don't know.
Old Mar 17, 2009 | 09:04 PM
bpowell688's Avatar
Will you sell just the camshaft?
Old Mar 18, 2009 | 09:33 AM
Dragaholic's Avatar
9 Second Club NA
Sure. PM sent.
Old Mar 28, 2009 | 06:55 PM
XpEdItIoUs's Avatar
Are the Valley Cover Gasket, Timing Cover Gasket, and Oil Pan Gaskets New?
Old Mar 30, 2009 | 09:42 AM
Dragaholic's Avatar
9 Second Club NA
Practically, they only have 10 passes on them.
PM Sent.
Old Mar 31, 2009 | 11:03 AM
nwi goat's Avatar
flow numbers on the heads?
Old Mar 31, 2009 | 09:36 PM
Dragaholic's Avatar
9 Second Club NA
They peaked around 380-390 cfm.
Old Apr 20, 2009 | 06:15 PM
james562's Avatar
Is the wolfe drag bar 100% complete and brand new? What size axle tubes is it for?
Old Apr 20, 2009 | 09:51 PM
Dragaholic's Avatar
9 Second Club NA
PM sent.
Old Apr 25, 2009 | 10:56 AM
dirtychevy99's Avatar
pm me best price on the longblock shipped to 75501 please thanks
Old Apr 26, 2009 | 08:59 PM
Dragaholic's Avatar
9 Second Club NA
PM sent.
Old Apr 29, 2009 | 09:22 PM
xxbottlefedxx's Avatar
Default price
What would you sell thd longbock for minus the stuff I can swap of my ls1.
Old Apr 30, 2009 | 07:16 AM
Stang's Bane's Avatar
Can't believe no-one has bought this yet. IF you want a proven drag motor, this is it..
Old Apr 30, 2009 | 06:56 PM
Dragaholic's Avatar
9 Second Club NA
xxbottlefedxx, the short block is what it is. Block, bearings, bolts, crank, pistons, rings, pins, rods, etc. There's really nothing to swap over. What you see in the list is what you get.
Stang's Bane, me either.
Old May 3, 2009 | 06:42 AM
98Camarod's Avatar
pm sent on the drag bar
Old May 3, 2009 | 07:53 AM
Austin@HPE's Avatar
Did you ever find out how much spray it can take. Also pm lowest price for long block picked up.
Old May 3, 2009 | 04:41 PM
Dragaholic's Avatar
9 Second Club NA
98Camarod, PM replied to.
gogto, I didn't. I'll email the engine builder tomorrow. The price posted is the price picked up.
Old May 4, 2009 | 05:49 AM
00BlackSS's Avatar
what is the stall on the converter? thanks
