No Longer Racing Sale
http://s15.photobucket.com/albums/a3...%20for%20sale/
For those of you that do not know me personally, I'm a retired disabled veteran. This past June, I've had my 3rd and hopefully last spinal surgery. What I hoped to be a great fix when they fuzed me together with some rods and screws turned out to be a train wreck. I was hoping for good results so I could finish this awesome project which was to be a Forged LSX 454 (Erik Koenig) with LS7 Top end. The problem is; that I am no longer able to climb under or on a car without worsening the side effects of my last surgery. So long story short, after discussing it with my wife at great length, I think it is time to move on and admire the sport as a spectator.
Below I will put a list of the parts that are for sale, whether they a "NEW" still in the box, or whatever their status is! If I cannot sell it as a package deal, then I will be looking for CASH plus your stock parts as an effort to put the Camaro back to stock, as it would be. I will be taking pics and posting a link on photo bucket over the next couple days.
Car Parts List
• NEW Nitrous Express 85mm Billet Nitrous MAF+Delco MAF 190
• Auto Meter Sport Comp Pro 2- 5”Tach w/playback/record/printer port/penlight 300
• Compucar Nitrous-in-a-bag cheater system 250
• NEW LS7 Intake 315
• NEW LS2/LS3/L92/LSX oil pan w/ gasket hardware/oil pickup tube/oil deflector 190 *PENDING*
• NEW Nitrous Express Automatic Bottle Heater 150
• AMS Racing Billet Aluminum Catch Can w/fittings 125
• NEW Katech Knock Harness with LS7 Sensor 100
• NEW LS2/3/7 Edelbrock 2-piece timing cover/sensor/harness 220
• NEW SPOHN WELD-IN Drag sway bar brackets 40
• NEW Casper Electronics A/F ratio pigtail for O2 35
• K&N Filter 30+stock
Spare set of 4:30 gears (perfect wear pattern were super quiet)
Edelbrock 3 ½” Y-pipe
• PRO 5.0 shifter 165 *SOLD*
• BMR REAR Lowering Springs *SOLD*
• NEW Metco Billet Valve cover breather 35 *SOLD*
• HKE LSX 454 Shortblock *SOLD*
Callies Crank 4.100 stroke
Callies 6.125 Rods w/ARP 2000bolts
Wiseco Forged Pistons 4.185 bore 15cc
Total seal rings
Federal Mogul 3/4 Groove main bearings
Chamfered Race rod bearings (coated)
ARP Main Stud kit
ARP cam bolt kit
HKE Camshaft (24X/25X on a 113+3)
• Moser Billet 1350 Yoke for 12 bolt 100 *SOLD*
• NEW DMH 4” Cutout w/electric motor 200 *SOLD*
• 1999 Z28 Sebring Silver w/ leather/t-tops $2,500. as a roller *SOLD*
Leather interior w/ Power driver seat (excellant condition)
T-tops with sun shades
Tinted Glass
12 disc CD-changer
UMI Weld-in sub-frame connectors
Hurst Line Lock
Camaro SS rear wing
Brand NEW VFN 3 1/2" Camaro SS hood
Carbon Fiber mirror covers
Carbon Fiber interior trim package
Billet Grille
HALO headlights with H.I.D. lighting package
Clear lens rear parking markers
Clear lens front turn signal/parking light assy.
• TREMEC T-56 upgraded “Just completely refreshed” 900. *SOLD*
Billet keys
Carbon Fiber Blocker rings
Steel 3-4 shift fork
1-2-3-4 synchro kit
1-2-3-4 Bronze fork pads
Input/output seals
New Input shaft
• Synister Motorsports lightweight Power Steering pulley 90 *SOLD*
• Synister Motorsports lightweight Tensioner pulley 60 *SOLD*
• QA1 lightweight R Model Drag Struts/Drag Shocks (just refreshed) 600+stock *SOLD*
• Eibach Drag Launch Spring system 200+stock *SOLD*
• NEW Nick Williams 90mm TB 300 *SOLD*
• NEW Dual Pillar Pod 40 *SOLD*
• SPOHN Chromoly TQ Arm with G-load brace 450+stock *SOLD*
• NEW BMR K-member 450 *SOLD*
• NEW BMR lower A-arms 400 *SOLD*
• NEW BMR upper A-arms 200 *SOLD*
• NEW GM LS1 motor mounts (2) 75 *SOLD*
• MOSER 12 bolt “Just completely refreshed” 1,500+stock *SOLD*
Moser 33 spline gun-drilled axles
Moser weld-in LCA relocation brackets
Moser Stud Girdle/rear cover
Moser rear Drag Sway Bar brackets
Eaton HD Posi Unit
Yukon 4.10 gears/Timken bearings/races
ABS sensor/ ABS reluctor ring
Metric & 1/2” Drag wheel studs
LT1 rear brake system & backing plates
coated housing
• 18” ADR M-sport Wheels Nitto 555R Tires 900+stock
Nitto 555 275/35/18’s (5k miles still has 98% tread)
Nitto 555R’s 305/35/18 (5k miles no tread left to speak of) *SOLD*
• NEW Billet Specialties Street Lite Drag Wheels $900 *SOLD*
• NEW Moroso DS2 Front runners (stickers still on them) Mounted on above wheels $200 *SOLD*
• M/T True Drag Slicks 28x10.50x15 mounted on above wheels $225 (90% tread) *SOLD*
• PST 4” Carbon Fiber Driveshaft w/cryogenic treated yokes 650+stock
*SOLD*
• Mufflex 4” catback w/Flowmaster 30 series race muffler 450+stock *SOLD*
• 2 Red Sparco Race Seats with slider racks (driver has small tears) 300 *SOLD*
• SPOHN Drag Rear Sway Bar w/rod links/u-bolts/poly bushings 300 *SOLD*
• NEW ATI Super Damper 400 *SOLD*
• Super Sucker Ram Air kit by Macewen Motorsports 150 *SOLD*
• SPOHN LCA’s 125+stock *SOLD*
• SPOHN P-Rod 90+stock *SOLD*
• NEW LS6 Ported high volume oil pump w/pickup o-ring 140 *SOLD*
• NEW LS2 timing set N-Motion 80 *SOLD*
• Texas Speed 85mm Air Lid 100+stock *SOLD*
DYNA BAT dry cell lightweight battery *SOLD*
DYNA BATT powder coated hold down bracket *SOLD*
ODYSSEY dry cell lightweight battery *SOLD*
Laptop for tuning (needs new battery) *SOLD*
(2) NEW RCI 5 point race harnesses *SOLD*
Thanks guys for stopping by and looking!
I have received a ton of well wishes on a good recovery from dozens of guys just stopping by the post; brothers-in-arms and just fellow enthusiasts. Thanks guys, I appreciate the kind words.
Jeff
Car Parts List
Total seal rings
ARP Main Stud kit
ARP cam bolt kit
Tinted Glass
12 disc CD-changer
Hurst Line Lock
Camaro SS rear wing
Billet Grille
Billet keys
1-2-3-4 synchro kit
Input/output seals
New Input shaft
Eaton HD Posi Unit
coated housing
*SOLD*
Jeff
pics of drag wheels? julians_fritos@hotmail.com
This is the style of wheels
http://www.billetspecialties.com/ite...id=251&pid=940
I will take pics for you though and send some to you. Please keep in mind; at the moment, they have BRAND NEW Moros DS2's mounted on the fronts and MT 28x10.50x15's mounted on the back. But I can have them removed if you don't want them. You may need race brakes to get them to fit. I've heard they may not fit LS1 brakes. I have LT1 brakes on my LS1 car.
'' Let me get pictures of this and the wheel's with the tires and LS7 intake... Email is mostwantedws6@yahoo.com and give me a price with everything shipped.... Also how many mile's or pass's on the Drag Bar???? I am ready to buy now if everything is good to go... Oh and sorry bro about the back injury and maybe one day you will be back
Which wheels, the 18" wheels and tires, or Drag wheels and tires?
Jeff
Whenever I hear a story like this I just cringe. My dad also is a disabled veteran with a spinal injury. He kept hearing stories like this and refuses to get surgery on his back. He has been living in extreme pain for a couple years now but will not take the plunge to surgery.
I'm sorry to hear what your going through. Good luck through it.
E
E
Do you have pictures od the adrs? Email to motoo344@gmail.com please.
http://s15.photobucket.com/albums/a3...0Camaro%20Z28/
These are the ADR's
Jeff
Can I get pictures of the seats? Dustinbake@gmail.com
I'll be taking a lot of pictures tomorrow and adding them to my photobucket account for everyone to see!
Jeff
