non-LSX Parts For Sale SBC, LT1, V6, etc.
LE Intake, LT1 N2o plate, 52mm TB, MSD Opti cap, CRT elbo, SLP fan swtch, 3" Steel DS
Old Mar 18, 2009 | 01:20 AM
94GreenMachine's Avatar
Default 374 heads, Intake, 52mm TB, MSD Opti cap, SLP fan swtch, 3" Steel DS
LE Intake **SOLD**
Nitrous Outlet LT1 n2o plate **SOLD**
CRT air-force lt-one Elbow **SOLD**
52mm Ported throttle body **SOLD**
94 MAF **SOLD**
All other parts moved to new thread with new, more appropriate title. Thanks.
Old Mar 18, 2009 | 01:50 AM
camaro_rs350's Avatar
can u send me a pic of the ported intake
Old Mar 18, 2009 | 01:57 AM
how much to ship the 94-97 ported intake to 94044
Old Mar 18, 2009 | 02:00 AM
PM sent with pic
All Prices are shipped so $100 unless you wanna pay more for shipping
Old Mar 18, 2009 | 02:01 AM
Originally Posted by 94GreenMachine
PM sent with pic
lol no 100 sounds good to me is that one fully ported or just the bore opening on the tb side
Old Mar 18, 2009 | 02:08 AM
The Stock one is just opened up to 58mm on the TB but otherwise stock. They do normally go for a little less as a bare intake but this one still has the Map sensor, Egr and Pcv on it. I can take them off if you want and sell it cheaper.
Old Mar 18, 2009 | 08:03 AM
Veganomics's Avatar
pm sent on n2o plate
Old Mar 18, 2009 | 01:15 PM
bigj2717's Avatar
Can I get pics of the pullies dbaladez@gmail.com and do you have the belt too
Old Mar 18, 2009 | 01:24 PM
pic of the pulley sent thanks.
Old Mar 18, 2009 | 02:19 PM
LT4 knock module **SOLD**
Old Mar 18, 2009 | 02:44 PM
March Performance Under Drive Pulley **SOLD**
Old Mar 18, 2009 | 08:09 PM
LE Ported Intake Manifold and CRT AirForce LT-one Elbo **SOLD**
Old Mar 19, 2009 | 02:55 PM
list updated, new parts added.
Old Mar 20, 2009 | 06:56 PM
t t t
Old Mar 21, 2009 | 06:03 AM
NotoriouSS SS's Avatar
-delete-
Old Mar 21, 2009 | 11:15 AM
LT1 Nitrous plate and MAF Sensor **SOLD**
Old Mar 22, 2009 | 05:26 PM
t t t
Old Mar 23, 2009 | 08:53 PM
PonyEater8788's Avatar
still have the opti
Old Mar 24, 2009 | 01:18 AM
Originally Posted by PonyEater8788
still have the opti
Sorry for the delayed response. yes the opti is still available.
thanks.
Old Mar 24, 2009 | 01:35 AM
runrun25's Avatar
Default what is your best offer for the tb shipped to laredo tx 78041
ALL PRICES INCLUDE SHIPPING AND PAYPAL FEES IN THE LOWER 48 ONLY
Pictures coming Soon. Most of the parts are still on the car but will be pulled over the next couple days
52mm GM Ported throttle body with port matched air foil. Iac and Tps included. 3k miles. $120 ****link to extreme efi on ebay***
MSD Opti Cap & Rotor 3k miles. Pn# 8481 w/ installation instructions $100
OPTI 93-94 Non Vented AC Delco 3k miles $150
MSD 82-02 Ignition Box Wiring Harness Adapter. Ease the installation of an MSD Ignition with this plug and play adapter harness. The harnesse provides a completely splice-free installation with matching connectors and corresponding wire colors. **Fits MSD to GM 95 and earlier Dual Connector Coils PN 8876. ***96 and new user single connector coil.
$22 shipped.
SLP Manual Fan Switch w/ instructions. Only installed for a few months, clean, no cuts, etc. $50
3” Steel Drive shaft has T56 / 4l60e yoke and 1350 spicer u-joint. Just balanced & painted black. Was used to connect a T56 to a 9” $100
Stock 374 Heads, Fully assembled, all stock valves, springs, rockers, etc. High mileage but in good working order. Car ran strong when taken apart. $200
94-97 Intake Manifold, ported for 58mm throttle body. Map, Egr & New 03+ Pcv included.
$100 Get it Complete with Rails, regulator and injectors for $150
94 Fuel rails w/ regulator $40
Set of 8 Stock 24lb injectors off 94. Good working condition $40
94 LT1 stock cam Camshaft Specs (12551705): 205/207 @ 50*, .447/.459" lift, 117 LSA $50
94 PCM with Stock Trans Am M6 tune $60
Set of Pistons and Rods from 94 LT1 $80
Stock lifters $25
Water Pump Drive Shaft $15
94 Formula 115mph gauge cluster $25
Oil Cooler / Filter Adapter $25
Knock Sensor $25
IAT Sensor$20
Steam Vent Tubes w/ bolts $25
LT1 Brake Master Cylinder and booster w/ reservoir $50
93-02 firebird fuse cover in charcoal Grey -$10
LT1 ICM 2k miles $20
Coolant reservoir with Battery tray-$25
LT1 PCM mounting bracket $25
Wiper arms $25
wiper motor $20
cowl plastic $25
Stock Crankshaft Hub – 25
what is your best offer for the tb shipped to laredo tx 78041????
