Parting out nitrous kit.. FJO, auto heater, basic wet kit w/ purge, etc.
Old Mar 25, 2009 | 07:22 PM
DuronClocker's Avatar
Default Parting out nitrous kit.. FJO, auto heater, basic wet kit w/ purge, etc.
FJO 2-stage/progressive nitrous controller with built-in WOT and window switches as well as 1st gear lockout. Bought new a year and a half ago, used for a weekend, and haven't used it since. SOLD
Nitrous Outlet fuel pressure safety switch.. same condition as all of the above.. SOLD
"Basic wet kit"...I bought this all used, and it worked great for the 2-3 bottles I put through it, but has been sitting since.
-10lb bottle with NOS "Hi-Flo" valve with bottle mounting brackets (bottle has been mostly sanded to bare aluminum to prep for paint, so not the prettiest..)
-Basic black nitrous bottle blanket from either Nitro Dave or HSW.. don't remember. I never finished the bottle because of how much I liked the look of this on the bottle (this was purchased new with the other items listed above and has very little use = clean)
-NX IceMan fuel, nitrous, and purge solenoids. Nitrous and purge solenoids are connected to each other with a bracket that mounts them in the TCS motor indent on the passenger shock tower (3AN purge line long enough to reach through the foam bumper cover support)
-NX Piranha nozzle with either 100hp or 125hp jets (various other random jet sizes included too)
-4AN feed line with NX filter long enough to go from the solenoid to the driveshaft hump with a few feet left over (probably long enough to reach to spare trunk area)
I'll include the relays I used and whatever wiring I've got with it.. but the wiring has all been cut for removal.. your choice to replace it or reconnect it. SOLD
NX bottle heater element (orange color) with Nitrous Outlet pressure switch. The heating element has a 2-pin GM weatherpack connector for easy removal from car. No need to pull the heater off the bottle, just remove the bottle brackets and disconnect the weatherpack connector, and pull the bottle out. You'll obviously get both sides of the connector to wire into your system. SOLD
Nitrous Outlet tunnel-mount bottle bracket.. same as above, bought, installed, and been sitting since. SOLD
Harris Speed Works switch plate for 6-speed '98 F-body console (not sure what other years fit). 4 lighted rocker switches, one momentary purge button SOLD
Old Mar 25, 2009 | 08:43 PM
02SS3098's Avatar
I'll take the switch plate shipped to 85029. How would you like payment?
Old Mar 25, 2009 | 09:56 PM
slow 99ss's Avatar
Default bottle bracket
pm sent on bottle bracket
Old Mar 25, 2009 | 11:17 PM
PM's returned
Bottle heater and switch plate sold.
