Misc stuff and car audio
Trying to generate some cashflow in this wonderful economy
All prices will be "or best offer", I just ask the offers are not ridiculously low
Only payment I accept is paypal unless picking the item up, then cash will be fine. My feedback here is over there <--- and on ebay it is http://jbrlsr.com/?aid=5336075431&bi...53DAllFeedback
All of it is 100% positive
Hooker Tips: dual outlet 2 1/2 in dual 3 out. used for 1 year, typical scratches and need a good polishing. $40 shipped to your door.
I have some stock stuff laying around:
Stock shifter from my long gone 98Z $20 shipped
Stock throtle body off of my 01 WS6 $50 shipped SOLD
Steering wheel & airbag from a 99 firebird $50 shipped
DRL module from a 99 firebird $50 shipped
Front shocks with springs still attached and rear shocks (springs already sold), shocks are decarbons off of my 01 WS6 $100 shipped for all of it or will seperate if people need.
If anyone needs a stock panhard bar or rear lower control arms let me know. I will do the group (ph and lower ca) for $30 shipped if someone needs them.
Car audio:
Alpine MRP-M650 mono sub amp
400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Tuned Bass EQ (0-12 dB bass boost at 50 Hz)
Subsonic filter (24 dB at 15 Hz)
MOSFET power supply
CEA-2006 compliant
STAR Topology (minimizes internal noise and prevents ground interference)
Speaker- and preamp-level inputs
Gold-plated screw terminals
Fuse rating: 30A x 2
12-13/16"W x 2-3/8"H x 9-9/16"D
I bought new at a local shop (Dedona) and used about 4 months. Been sitting in my condo since. $150 shipped NO LONGER AVAILABLE
Quantum Audio QS1500d mono sub amp. I bought this as plan b if the amp I really wanted didn't come thru. The main selling point on this for me is, like the Alpine, it does its rated power (1500) at 2ohm which is what my subs are wired for.This amp is brand new in box. Only opened to take pics and includes the remote bass **** for easy adjustment of bass level. It is 750x1 at 4ohms and 1500x1 at 2ohms. $150 shipped SOLD
Only payment I accept is paypal unless picking the item up, then cash will be fine. My feedback here is over there <--- and on ebay it is http://jbrlsr.com/?aid=5336075431&bi...53DAllFeedbackAll of it is 100% positive
Car audio:
MOSFET power supply
CEA-2006 compliant
Car audio part deaux:
Nakamichi PA-506
This is one of my prized possesions! This 6 channel monster was built for Nakamichi by Zed Audio. If you know anything about amps then you are aware of what that means. If not, do a quick search to see the quality that goes into any amp built by Zed Audio. This amp will run an entire system but is better served as an amp to run a 3 way active front stage in a sound quality setup. If you enjoy listening to music of the highest sound quality, then this amp is for you. Here are the specs: 6 x 50W @ 4 ohms
6 x 100W @ 2 ohms
3 x 200W @ 4 ohms bridged
1 x 250W @ 2 ohms bridged (ch 5/6 only)
THD: <0.01%
S/N Ratio: 100dB
Power Bandwidth: 10Hz ¡dum 30kHz (-1dB)
Dimensions: 18.9" x 9.6" x 2.6" (48.1cm x 24.4cm x 6.7cm)
Built by Zed Audio
Price is $350 shipped. This amp was 3 x that when new and this one is in great shape. 9/10 looks and 10/10 functionaly.
PPI Precision Power Power Class series PC6600.2
Used but in good condition PPI powerhouse 6 channel amp.Has a few scratches but nothing too bad and has no bearing on performance. This amp is a beast. Here are the specs:6 x 50W @ 4 ohms
6 x 100W @ 2 ohms
THD: 0.02% (4 ohms)
Freq. Response: 4.5Hz ¡dum 100kHz (¡¾0.5dB)
S/N Ratio: 110dB
Damping Factor: >500
Max. Current Draw: 100A
Fuse: External 80A
Dimensions: 19.75" x 8.98" x 2.24" (50.2cm ¡¿ 22.8cm ¡¿ 5.7cm)
Manufactured in 2000, the "point2" indicated the move by PPI to install beefier components in this line.
Run your entire system off of 1 amp. This is from when PPI was still owned and operated in Arizona. Old school sound quality goodness!! Price is $250 shipped.
Diamond Audio D6 12" D4ohm
A really great sub, only single sub I ever ran that was louder was a RE15. There are a few dings in the cone but none go all the way through and have not affected performance one bit. I also have a ported box built to specs for this sub that really mates up to it very well! Box is not vehicle specific but will fit in the rear well. I had it sideways in the ttop well b4 I built my new box.
12" Dual 4 Ohms D6 Series Subwoofer
Power Handling:
Peak: 1200 watts
RMS: 600 watts
Impedance: Dual 4 ohms
Hard anodized alloy cone woofer
NBR "Omega" Surrounds
Cast aluminum alloy frames
Dual mirror-image flat spiders
Inter cooled motor design
Vented pole piece
Aluminum dust cap
Integrated heavy duty lead wires
3" Extended voice coils
Price for sub alone $125 shipped
Sub with box $175 shipped
Box alone $75 shipped
Nakamichi PA-506
6 x 100W @ 2 ohms
THD: <0.01%
S/N Ratio: 100dB
Built by Zed Audio
6 x 100W @ 2 ohms
THD: 0.02% (4 ohms)
S/N Ratio: 110dB
Fuse: External 80A
Power Handling:
Peak: 1200 watts
RMS: 600 watts
Vented pole piece
Aluminum dust cap
My original setup was a A404 and A600.2 I miss my arts
My final (yeah right!) setup will be a Zuki small eleets 4ch and a Phoenix Gold Xenon 1200.1
Should be ok for a little while anyways
