FS/FT: HUGE LIST OF PARTS! LS1 F-body and some C5 (N. Texas)
I've got a bunch of extra stuff I'd like to get rid of...researched pricing as best I could, but there's a lot here so I couldn't find everything. So if you think I am way out of line on something, PLEASE PM OR CALL ME.
With that being said, all prices are OBO plus shipping. I'm reasonable, so all reasonable offers will be considered. I am in N. Texas (Mckinney area). Zip is 75071. Cash, PayPal, Cashiers Check, or MO preferred.
I will work on pics over the next week or so, but it will be awhile before everything is photo'd and uploaded. In the meanwhile, if you want a pic of something specific, just ask and I can snap a phone pic and text or email it to you.
Stock LS1 Stuff
LS1 Intake bare, seals only $40.00
LS1 F-body K-member $100.00
LS1 stock cam (at least 2 on hand) $25.00 ea
C5 Air box w/ filter $20.00
GM LS1 Head bolt kit (2 NEW kits), early style, but need to double check! $40.00 for both
LS1 Rocker Arms $40.00/set
LS1 Rocker Stands $10.00/pair
LS1 MAF (descrened) $40.00 ea
C5 A/C bracket $45.00
Z06 85mm MAF '01 off 8k mi. Z06 $85.00
6.0 Crank (Rusty, will need .010/.010) $60.00
6.0 LQ4 Rods/Pistons $85.00
LS1 valley cover $25.00
Stock '98+ F-body Chassis/Suspension
Stock F-body LCA's $20.00/set
Stock F-body PHR $10.00
F-body PHR support $10.00
LS1 F-body front swaybar $40.00
LS1 F-body rear swaybar $20.00
4-channel 10-bolt housing $85.00
F-body TQ arm $40.00
F-body tunnel brace $10.00
F-body DeCarbons (front set) $20.00
F-body DeCarbons (rear set) $20.00
Full set V8 F-body coil springs $40.00
Interior
Charcoal Firebird DS door panel (cracked where they all do, but otherwise clean) $20.00
Tan Camaro Door panels $40.00 for both
Tan Hatch panels $15.00
Stock Transmission Related Parts
SLP/Hurst shifter $45.00
M6 rubber shift boot (trimmed) $10.00
C5 shifter $25.00
Aluminum Driveshaft $85
C5 Slave cylinder $20.00
LS1 F-body stock shifter $15.00
F-body T56 crossmember $25.00
3.23's out of a 10-bolt $50.00
'99 4L60E no 3rd or 4th $100.00 picked up only
Stock Exhaust Parts
01 Z06 H-pipe w/ cats $85.00
02 Z06 H-pipe w/ cats $75.00
Z06 Manifolds $75.00
01-02 LS1 F-body Manifolds w/ cats $110.00/set (both mani's w/ cats)
98 LS1 F-body Y-pipe $30.00
01-02 LS1 F-body y-pipe $45.00
CTS-V Manifolds w/ cats $120.00
Stock Z28 Catback no tips $35.00
SS/WS6 catback w/ welded-in Flowmaster, cutout on I-pipe $50.00
Aftermarket Parts (Engine, Fueling, etc)
RX C5 fuel system-NIB $240.00 REDUCED!
Billet Ported MAF ends $45.00
DRE Billet Valve cover spacer kit (accepts stock gaskets) NIB $125.00
DRE LS1 Shaft-mounted Adjustable Roller Rockers--Low miles $325.00 dreracing dot com to see what these look like
Rollmaster double roller timing set Like New $75.00
Metco Billet Breather cap Like New $45.00
DRE LS1 Rev-kit-low miles $120.00
Smith Bros 1-pc CM pushrods 7.500" new $70.00
Smith Bros 1-pc CM pushrods 7.550" new $70.00
C5 TCI Elastomer balancer 25% underdrive NEW $275.00
CamMotion 258/265 .680/.680" 110+4 NEW (max effort 402+ci) $250.00
CamMotion 236/240 .629/.629" 112+4 NEW (aggressive lobes, 346+ci) $250.00
CamMotion 257/260 .64x/.660" 111+4 NEW Max effort 402+ci $250.00
CamMotion 239/243 .612/.618" 112+4 Max effort 346-375ci 490+ RW capable w/ good heads 3k miles $200, back available!
CamMotion 246/250 .632/.629" 113+3 great 402+ci street/strip cam 5k miles $200.00
WILL NEED TO VERIFY P/V ON CAMS!!
Aftermarket Transmission Related Parts
Slave Shim $10.00
LS1 M6 Fidanza Aluminum flywheel, needs $80 face $125.00
Aftermarket Chassis/Suspension Parts
Madman/TR/HAL rear shock mount tab kit NEW $30.00
BMR Driveshaft loop (red)-NEW $80.00
F-body 4-pt. bolt-in roll bar Mild steel, made custom. Has over-the-seat rear bars and looks somewhat similar to a Wolfe. I bought it off here years ago. $85 picked up or $100 + shipping, Still available!
Aftermarket Exhaust Parts
Edelbrock Y-pipe (new) for LS1 Victor headers $60.00
Magnaflow 2.5" SS turbo-style mufflers (same side in/same side exit) $40.00ea
Thanks for looking!
John
214-674-0141
Stock LS1 Stuff
Interior
C5 shifter $25.00
Stock Exhaust Parts
Slave Shim $10.00
Thanks for looking!
John
214-674-0141
Last edited by SSP Racing; Jun 29, 2009 at 11:58 PM. Reason: lowered some prices and updated list
What were the DRE shafts made for? Stock valve length LS1 headed stuff?
DRE is very high quality stuff. The rev kit is pimp **** too. Get back with me on that stuff and ill pick that up with the cats I sent you a pm about.
Oil pan needed for sure here.
Does the Fbody alternator fit a 5.3 truck motor??? Also could use a water pump if you know you have a good one. I'll get back with ya on some other stuff in a few minutes. Paypal ready!
