ET 225cc heads FS
These are a set of 11* ET 225cc that were Custom CNC ported from Cary at ETP to 235cc. They are 4 bolt design and are set up for a solid roller camshaft, included will be a set of hydrolic springs with the custom ET rocker mounts. $2300 OBO
The heads flowed 356 on the intake side, 245 on the exhaust with no pipe, 287 with 1 7/8 pipe. chamber volume is 60 cc.
26120-16 Comp beehive springs are the Hyd springs and the solids were assembled at ET (im not sure of the pressures) the cam spec used was 272/284 720/745 115. They are good over .800 lift.
.200" 145 113
.300" 225 159
.400" 282 213
.500" 320 229
.600" 344 236
.700" 356 242
.200" 145 113
.300" 225 159
.400" 282 213
.500" 320 229
.600" 344 236
.700" 356 242
