DynoTune nitrous kit
Traded my car off, so I no longer need the nitrous kit. Priced to sell!
It's a dry kit from DynoTune with several additions. Everything you need to install it is included, minus a fuel solenoid if you'd rather run it as a wet kit. Kit comes with:
860 Performance heated bottle brackets
10 pound DynoTune bottle (bottle is completely full)
Black bottle blanket
J shaped blowdown tube /w extra burst disk
16ft -4an hose (main feed)
Nitrous filter (screws directly into the 250hp solenoid)
250 hp nitrous solenoid
175 hp nitrous solenoid (I used as a purge)
2x 1ft -4an hoses
2x dry style nozzles
1x 3 foot -4an hose
Various jets (.32 up to .44)
DynoTune digital nitrous pressure gauge + sender (red LED display)
Summit Racing window switch
Cyberdyne fuel pressure gauge + sender
All fittings/adapters needed to hook all lines + senders up
~60 feet of spare wire loom
3 spools of spare wire (at least 100 feet leftover)
Fuel pressure safety switch (set to cut under 35 PSI, was on an LS1)
The only part that doesn't look "like new" is the 175hp solenoid. The only defect on it is the DynoTune sticker is scuffed a little bit. Doesn't affect the solenoid, it operates flawlessly
I spent well over $1100 for this kit, but I want it gone. $500 shipped takes it! I can do PayPal, money order, or cash on a local pickup. If I have to ship the kit, the bottle will be emptied, as I don't know of any delivery company that will deliver a full nitrous bottle
2x 1ft -4an hoses
1x 3 foot -4an hose
great price for a great kit. Bump for you.
If you decide to seperate, I'd be interested in:
*DynoTune digital nitrous pressure gauge + sender (red LED display) if it's the round type
*Fuel pressure safety switch (set to cut under 35 PSI, was on an LS1)
*J shaped blowdown tube /w extra burst disk
*Nitrous filter (depending if it would fit inline on a -4an line)
*1x 1ft -4an hoses
*1x 1ft -4an hoses
If I end up selling the kit off seperately, I'd be glad to do so. Obviously I'd rather sell it all at once, but sometimes it's tough to find a buyer
I will post pics up tonight, not sure why I didn't get up them before I started this thread
As promised, here are the pics!
Heated brackets, bottle, main feed, blowdown tube, bottle blanket
As it would sit in the car
Warning label
Plumbing (purge, 3 foot line, filter, main solenoid, T, 2x 1 ft lines 2x nozzles) and electronics (fuel pressure safety switch, fuel pressure sender, fuel pressure gauge, nitrous pressure sender, nitrous pressure gauge, window switch)
Solenoids (big one is clean, the smaller one has the scuffed label..both function perfectly)
Dry shot nozzles (the gap is to secure the nozzles to the air lid)
Fuel pressure sender/gauge, fuel pressure safety switch (the whole unit hooks straight to the schrader valve, easy install!!) nitrous pressure sender/gauge
Window switch with soldered terminals
Warning label
