Slp timing chain, oil pump, comp r lifters and much more
All these parts are used with about 5k on them
slp double row timing chain with bolts and spacers SOLD
slp ported pump SOLD
comp r lifters SOLD
comp standard lifters a couple are a little soft the rest are good make offer
stock valley cover with gasket 50.00
stock water pump SOLD
patriot dual springs SOLD
bmr drive shaft loop bolt in SOLD
spec stage 3 clutch and pressure plate about 5k on it , still worked fine but trans came apart so put a better one in
stock suspension parts make offer:
lower control arms
panhard rod
torque arm
front springs
front and rear shocks
k-member
upper and lower control arms
I will add some more stuff in a few days
comp r lifters SOLD
lower control arms
panhard rod
torque arm
front springs
k-member
