Moser 9" Rear FS in VA
Sold Pending Funds
I bought this rear from another member on here around 2/09. There is absolutely nothing wrong with this rearend. As far as I know it has never even seen the drag strip. I have changed my mind on what I want to do with this car and would like to take it back alittle closer to stock. Plus alittle extra cash to pay the bills on my upcoming surgery wouldn't hurt either.
Details on the rear:
-Moser Housing
-31 Spline Axles
-True Trac Diff
-4.11 Gears
-Aluminum Center Section
-Fill and Drain Plugs
-Lightening Hole Option
-Powdercoated Black, which is starting to flake on the front of the axle tubes.
-4 Channel ABS
-UMI Lower Control Arm Relocation Brackets
-Spohn Sway Bar Brackets
-Stock Width
-Stock Brake Backing Plates
I have the original sales reciept ('07) with this rear which totals around $3500 with driveshaft. I will let it go for $2000 plus trade of a stock 10 bolt with 3.42's and 4 channel ABS, preferably auburn diff. Car is a daily driver so the 10 bolt is a must. Please do not try to trade me your broken 10 bolt, I dont want it! May also be able to work in a trade for some 17x11-17x9 zr1's, let me know what you have. Any questions please feel free to PM me.
Edit: Also wanted to add that the Inland Empire Driveshaft for this rear can go with this for trade of a stock aluminum driveshaft.
Thanks, Kyle
-Moser Housing
-31 Spline Axles
-True Trac Diff
-4.11 Gears
-4 Channel ABS
-Stock Width
Thanks, Kyle
