FS : 2002 Trans Am Ws6 408 H/C/I/E
My 2002 Silver Trans Am is for sale. This car is a ALL MOTOR STREET BEAST. When I bought this car in March of 2007, it was BONE STOCK. ALL of the work and mods were done by a Professional shop located in Pearland, TX called G-Force Motorsports. The car has 68,xxx miles. The 408 was installed when the car had 63,xxx miles. This car is located in Sugar Land, Tx. This car has around $25k including parts and labor. I'm letting this car go for $17,000 OBO. I do have most of my receipts for this car and it will be showed and given at sale. I am also willing to do a trade with a Trailblazer SS or a 4x4 truck, but it needs to be driving range to check the cars out and needs to be able to tow a 4k lb boat. Dyno sheet, pics, and video is below.
Prefer local buyers so they can come and check the car out but if it needs to be shipped then buyer is responsible
Suspension
-KYB Adjustable AGX Shock (Rear)
-KYB Adjustable AGX Shock (Front)
-UMI Tubular 3-Point Subframe Connectors
-UMI Perf. Single Adj. Lower Control Arms & Panhard Bar Kit
-UMI Tunnel Brace Mounted Torque Arm
-SLP Strut Tower Brace
Rear End
-Motive Performance 4.10 Gear Set
Transmission
-1A package (SixSpeedInc)
-Reverse Gear
-6th Gear
-5/6 Slider
-Bearing Kit
-Prothane Transmission Mount
Engine
-11:1 408 built by HK Enterprises (5,xxx MILES)
-Trick Flow 235cc Cylinder Heads
-ASP Racing 25% Underdrive Crank/Alternator Pulleys
-LS1 SLP "FlowPac" Cold-Air Package
-Prothane Motor Mounts
-Greg Good ported FAST 90mm Intake
-Nick Williams 90mm Throttle Body
-Camshaft (258/262 .645/.645 112 LSA)
Exhaust
-1 7/8" Kooks Headers
-Kooks Offroad Y pipe
-Cutout
-Magnaflow catback
Brakes
-EBC Red Stuff Brake Pads (Compound) - Rear
-EBC Red Stuff Brake Pads (Compound) - Front
-EBC Drilled/Slotted Rotor
Clutch
-Textralia OZ700 Series Clutch(Steel Billet) (15k miles)
-Pro 5.0 Shifter T56
Rear End
-Stock 10 bolt
Wheels
-Black z06 Motorsport 18 x 10.5 REAR
-Black z06 Motorsport 17 x 9.5 FRONT
Tires
-g-Force T/A KDW NT 295/35R-18 99Y BSW (REAR) BRAND NEW TIRES
-g-Force T/A KDW 275/40/17-98y (FRONT) 15k miles
Tint
-35% Driver and Passenger windows
-5% Rear window
^^^ cutout is closed in the video
Suspension
Rear End
Transmission
-Reverse Gear
-6th Gear
-5/6 Slider
-Bearing Kit
Engine
Exhaust
-Cutout
-Magnaflow catback
Brakes
Clutch
Rear End
-Stock 10 bolt
Wheels
Tires
Tint
-5% Rear window
replied, i just noticed you need something for towing, but its a ford....
http://cgi.ebay.com/ebaymotors/ws/eB...=tab%3DSelling
