LME Built boost ready 370 Long or Short block NEW
Ok I have an LME built 370 for a supercharger or turbo setup. Everything is brand new never ran or even installed.
specs:
AFR 205 heads with 921 springs
Chromoly pushrods
Callies 4340 crank
Callies H beam rods W/ARP 2000 7/16" bolts
Wiseco turbo duty pistons
C&A fire power rings
Clevite bearing through out
ARP main studs
ARP head studs
Custom Cam specs:228 223 dur. @ 050" .595".578" lift on a 114lsa in @ 110 ICL
Roll master double roller timing set with torington bearing and nitrided gears.
Melling Oil Pump ported and shimmed
LS1 Lifter tray and bolts
Comp cam Hyd roller lifters
Cometic head gaskets
It was assembled and setup by LME and is still in the crate!! Compression should be around 9.0 to 1. I built this to be a great street engine with good low end and also to spool turbos up faster. I was told this engine could handle 1K flywheel horsepower! I really dont want to ship this but if buyer arranges it I might be willing to but at there expense. I will drive up to two hours to deliver or meet up with someone. Also might be willing to sell as a short block minus the heads and cam oil pump and timing chain but would definitely prefer to sell whole. I would like to get $7,200 OBO. PM or email me at corvette142@yahoo.com with any questions.
specs:
Chromoly pushrods
Callies 4340 crank
ARP main studs
ARP head studs
