Texas Classifieds Sell your items and vehicles here in Texas
shop full of parts for 93-02 f-body's in dfw
Old Jul 30, 2009 | 02:30 PM
STS95T/A's Avatar
Default shop full of parts for 93-02 f-body's in dfw
here is a short list of everything i can think of
if you need anything else feel free to pm me
complete 95 LT1 motor with all accessories, wireing, and pcm. has 90k miles and ran great when pulled-$900
3.42 3 channel rearend out of a 96 camaro Z28-$240 complete with brakes
LT1 dual fan assembly-$60
LT1 M6 radiator-$40
LT1 T56 transmission with 85k miles-$800
LT1 t56 bellhousing-$80
LT1 t56 clutch basket-$60
LT1 t56 pedal assembly with sensors/pigtails-$60
stock complete LT1 t56 shifter-$40
LT1 t56 clutch hydrolics (resivor with line, master cyl, steel braded line, and slave cyl)-$70
LT1 t56 tranny crossmember-$25
LT1 t56 torque arm mount-$20
LT1 t56 clutch fork with bolt-$50
LT1 t56 slave cyl spacer-$20
LT1 t56 rubber shift boot-$15
complete LT1 t56 tranny conversion including tranny, bellhousing, clutch basket, shifter, hydrolics, pedals, rubber shift boot, and all brackets/hardwear)-$1100
LT1 plastic fuel lines-$25
93-94 LT1 timing cover-$30
95 LT1 timing cover-$40
96-97 LT1 timing cover with crank sensor-$50
LT1 valve covers-$20 with gaskets
94-97 LT1 intake-$50
94-97 LT1 fuel rails with regulator-$40
94-97 LT1 throttle body-$25
93 LT1 intake-$50
93 LT1 throttle body-$25
LT1 accessory bracket-$25
LT1 idler pulley assembly-$10
LT1 power steering pump-$25
LT1 power steering fluid resivor-$20
LT1 H2O pump-$40
93-95 LT1 ICM/coil assembly-$25
96-97 LT1 icm/coil assembly-$25
LT1 643 casting aluminum heads with comp cam springs-$220
LT1 firebird/trans am headlights-$75 each
LS1 steering coupler-$20
LT1 steering coupler-$10
firebird/trans am electric mirrors (i have red withe and black for the passenger side and red and black for the drivers side)-$25 each
firebird/trans am headlight control module-$20
93-97 rear view mirror-$20
96+ dual horn assembly-$20
LT1 MAF sensors-$30 without screen or $40 with screen
good 93-02 battery tray/coolent tank-$25
LT1 e-brake cables (3)-$40 set
LT1 rear brake assembly (includes calipers, backing plates, rotors, hydrolic brake lines, and all hardwear)-$100
93-97 passenger airbag-$25
98-02 passenger air bag-$25
95-99 firebird/trans am drivers airbag in gray-$40
00-02 firebird/trans am drivers airbag in ebony-$50
93-99 camaro drivers airbag-$40
96-97 air bag sensor-$25
93-95 air bag sensor set (3)-$25
LT1 intake elbow in great condition-$25
93-97 camaro headlight bar complete with headlights-$75
93-97 firebird/trans am headlight support bar-$50
LT1 throttle cable-$20
93-02 t-top weather stripping-$30 pair
dot matrix t-tops (93-94)-$70 each
tinted t-tops (95-02)-$80 each
t-top divider (on roof)-$20
t-top holders (in trunk)-$25 in ebony or charcole
t-top brackets set-$10
firebird window/lock/mirror controls in ebony or charcole-$40 drivers and passenger
auto or manual steel driveshaft-$30
LS1 front calipers-$60 pair
97+ camaro monsoon cassette player-$40
93-97 formula/trans am drivers tail light-$60
93-02 firebird/trans am tail light harness-$25
firebird dash vents in charcole gray-$5 each (i have both ethe center and out side vents)
93-96 camaro radio bezel-$20
97-02 camaro radio bezel complete-$30
93-99 firebird radio bezel in charcole gray-$20
stock LCA's-$10 each
stock PHB-$10
i have many many other parts, too many to list. so if you need anything else feel free to pm me
i'm located in mansfield tx 76063
my paypal is f-bodyparts@hotmail.com
thanks
robbie
Old Jul 30, 2009 | 04:11 PM
capjmp's Avatar
Do you have a center console arm rest for 00 camaro in grey.
Old Jul 30, 2009 | 04:38 PM
mistamista's Avatar
i need a rear o2 for my 96
Old Jul 30, 2009 | 07:51 PM
STS95T/A's Avatar
sorry but i do not have either right not
thanks
robbie
Old Jul 30, 2009 | 08:41 PM
dudeman's Avatar
do you have an ls1 short block?
Old Jul 30, 2009 | 09:54 PM
STS95T/A's Avatar
sorry but no LS short block
thanks
robbie
Old Jul 31, 2009 | 09:10 AM
SSnemesis's Avatar
Would you happen to have any longtubes laying around for an '02?
Old Jul 31, 2009 | 04:05 PM
STS95T/A's Avatar
sorry but no LS long tubes
thanks
robbie
Old Aug 1, 2009 | 12:56 PM
NemeSS's Avatar
would u happen to have a ny ls1 fbody shorties laying around?
Old Aug 6, 2009 | 08:24 PM
STS95T/A's Avatar
sorry but no LS1 shorties
Old Aug 21, 2009 | 08:19 AM
Stang's Bane's Avatar
I need the
I am assuming it will work on a ls1 as well??
Old Aug 22, 2009 | 10:52 AM
STS95T/A's Avatar
pm sent
to the top
Old Aug 24, 2009 | 04:36 PM
383_Z's Avatar
do u have a black center console for a 93-96 lt1. 6 speed
Old Aug 24, 2009 | 09:49 PM
STS95T/A's Avatar
sorry but i do not have one in good condition
thanks
robbie
Old Sep 3, 2009 | 10:55 PM
Modern_Muscle's Avatar
any body parts? I need basically the whole front.
Old Sep 3, 2009 | 10:59 PM
whitehooptie's Avatar
Have a steering rack by chance?
Old Sep 5, 2009 | 10:01 AM
hotrodscrap's Avatar
Have an LT-1 auto radiator?
-SS
Old Sep 5, 2009 | 12:05 PM
Super-Bat's Avatar
A Trans Am 3rd brake light for the High-Rise hatch? 98-02
Old Sep 6, 2009 | 05:02 PM
You've got mail, and questions!
-SS
Old Sep 7, 2009 | 11:43 AM
ElkySS's Avatar
tryed to pm, box full. need trans am side skirts. will take in any color but prefer black. need hardware too. pm me price shipped to 77089 houston
