Mickey Thompson DR's, Chrome ZR1's, 4L80, LS1 pullout
2 Mickey Thompson P275/40R17 drag radials mounted on OE wheels 17x9.5 Crome ZR1's, I bought this setup new in march, I have only used them at the track, absolutely no street use, tires still have 5/32" of tread, Wheels are nearly perfect, just a couple nicks on the outer rim of one wheel (pictured)
$450 shipped SOLD!!!
4L80 automatic trans pulled from a 2006 Silverado with 30K miles, the truck was a 4X4 so the tranny would need a tailhousing for use in a car, I also have the transfer case still bolted to it if interested, I could make shipping arrangements but would prefer local pick-up.
$700 + shipping or local pickup
Bone stock LS1 still in my 2000 Camaro, does not include harness, pcm, or ignition coils. Car only has 47,000 miles, the problem with this engine is it has a broken starter bolt hole (pictured) i'm not sure if a good machine shop could repair it or not, i do not have the piece that broke off, I bought the car this way not knowing it, someone had fabbed a bracket that bolted to the bellhousing through one of the bellhousing bolts that has a nut on top of it and a really long starter bolt, it works, it's just not "right" I am building a 408 stroker and will have no use for this engine. If interested, I have a 5.3 iron block that can be bored large enough for the LS1 internals to work in. I haven't pulled it out of the car yet so if you'd like to see it run I can arrange that. Local Pickup prefered, I am willing to haul it partways, 100 miles or so, from Zurich, KS
$800 + Shipping or local pickup
I can get more pics of any of it if interested, thanks
http://s911.photobucket.com/albums/a...view=slideshow
