Parting Out 383 and L33 Engines
I’m parting out my 383 and need to move these items quickly, all items priced to sell, but I'm still open to offers. The engine was in perfect mechanical order when pulled from the bird. I’m selling most every major component except the crank and rods.
“383”
All items have ~25K miles unless otherwise noted:
·Bare Block $300 (will not ship):Gen III LS1 aluminum, 3.905” bore, pistons come 0.010” out the hole. Machine work by HKE. Includes the main caps. Photo1 Photo2 Photo3 Photo4
·Diamond pistons $300: Forged aluminum, 3.905” bore, 7cc dish, valve reliefs, for use with 6.125” rod. Includes wrist pins and rings. Photo1 Photo2 Photo3 Photo4 Photo5
·HPE “S-Cam” $200:238/242/115 onXER lobes. Photo on request - it looks just like a new cam.
·Jesel Sportsman Shaft Rockers $350: Non-adjustable 1.7:1. Includes stands and mounting hardware. You will need taller valve covers or valve cover spacers to use these rockers. Photo
New items added (Aug-15-2009)
I have this add up on a few forums. Please send me a PM if you are interested in any of these parts. If you are inquiring to "shipped" prices, please include your zip code. Free bumps to the top are appreciated.
PayPal or cash in person only.
“383”
- LS6 Intake Manifold $325: includes TB and port gaskets. Photo1 Photo2 Photo3 Photo4 Photo5
- OEM Ported and Polished Throttle Body $100: Just the TB no electronics. Photo1 Photo2
- Jet Hot Headers $200 (will not ship): Just the headers and block off plates. You will need your own Y pipe. There is some minor surface rust, no dents, no dings, work great! Photo1 Photo2
- SVO 42's (Green Top) $200: These flow ~53 LB/HR at the LS1 rail pressure. All o-rings have been lubed for storage/shipment. Photo1 Photo2 Photo3
L33 Parts. All parts are from an '07 Sierra pull-out with ~70k miles. I have never seen this engine run. I have visually inspected all of these items and they all appear to be in solid mechanical order, but I make no guaranties.
·OEM Rotating assembly$50 (will not ship): Crank -3.622” stroke; Rods– 6”; Pistons– 3.788”. Photo's on request. Looks just like a stock rotating assembly with 79k miles on it.
·Front and Rear Covers $50: Front and rear engine covers with gaskets. These will fit all GenIII engines. Photo1 Photo2
·OEM Water pump $15:Includesthermostat, thermostathousing, and gaskets. I have no idea if the pump actually works or not. Photo
·OEM Hydraulic Lifters$25: Includes 8 lifters, 4 trays, and all hardware. Photo on request. Look to be in good shape.
·OEM Exhaust Manifolds $25: Includes the manifolds, heatshields, bolts, and gaskets. I believe these are the ones you want for custom turbo applications. Photo on request.
·OEM Intake Manifold/TB: $100: Includes the intake manifold, fuel rails, fuel injectors, and DBW throttle body. Photo1 Photo2 Photo3 Photo4 Photo5
·OEM Coolant Plugs and Cross Over Tube SOLD: Includes bolts. A must for LS6/FASTintakemanifold upgrades.
·OEM Truck Ignition Coil Packs SOLD: Includes all mounting hardware (brackets and bolts)
·OEM Cylinder Heads SOLD:799 casting, includes valves, springs, and theTTY head bolts
·OEM Oil pan SOLD:Includes windage tray and oil pickup tube.
I will have more items up for grabs in the near future. Stay tuned…
Last edited by TAQuickness; Aug 19, 2009 at 06:20 AM. Reason: updated list with sold items
Buuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu uuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuump
