FS- L76,LS3 manifold, FAST 90mm throttle body, & Venom 42# injectors
First item is a brand new L76 intake manifold. This is the manifold you will need if you are switching up to square port L92, LS3, or possibly even the LS7 heads. I am saying "possibly" because I'm not sure whether the difference in angles with the LS7 heads effects the manifold mounting. It has the four bolt tb mounting and will work with the FAST tb.. I purchased this for $350 shipped to me. Looking for $275 shipped cont. US.
Second item is a FAST 90mm throttle body. You guys all know exactly what this is. It was only used for a few dyno runs and then switched out for a 92mm. Very clean and ready to rock. These are $400+ new. I'll ship this one cont.US for $275 as well.
Third item is a set of 8 brand new Venom 42# injectors. LS engines using the long injector body. Will work on later model LS engines with the short injector bodies. But will require more switching out of fuel rails, mounts, and harnesses than it would be worth to most of us. I never used these because I ended up going forced induction on a 427 cid instead of n/a and required 60#. These are new and never used. I paid $340 shipped for these. $275 shipped cont. US as well.
Will ship all three together for $550 cont. US
PM me with any questions or more pics.
Last edited by 108dragon; 08-11-2009 at 12:45 PM. Reason: have no idea how that got in there...
