Garage clean out, assorted parts
I’m trying to free up some space in the garage and the shed. If you see something you want and don't agree with the price, MAKE ME AN OFFER! Also would consider a partial trade for an aftermarket LT1/4L60E Trans mount torque arm. Additionally, more pics/high res pics can be emailed if required. Thank you for looking and have a good day.
Stock rear sway bar from a 96 WS6 (will include mounting bushings, but NOT the mounting brackets or end links) $10
Working blower motor pulled from a 96 WS6 with 80k miles when removing A/C. $5
One 96-97 LT1 O2 sensor extension wire. $5
Opti harness from a 96 WS6 with 80k miles. Harness works great, but needed the molex that joins the opti harness to the main wiring harness from when a Dynaspark opti was installed. The wires were depinned, NOT cut. If you have your existing, non working harness you can swap the molex from yours onto this one and be good to go. Takes less than a minute to swap the molex. $5
6 LT1 stock valve cover bolts. Left over after a Taylor OVC conversion . $5
