FS: LS6 Intake, Jessel Rockers, Cam, Block, PPTB, Headers, Injectors + OEM Parts!!!!
Old Aug 21, 2009 | 07:25 AM
TAQuickness's Avatar
Thumbs up FS: LS6 Intake, Jessel Rockers, Cam, Block, PPTB, Headers, Injectors + OEM Parts!!!!
I'm parting out 2 engines prepping for a new build. All items off the 383 were in perfect mechanical order when disassembled. All items off the L33 were from a ~70K mile pull-out. I have visually inspected all L33 items and all appear to be in good working order; however, I have not seen this engine run and cannot vouch for the mechanical soundness.
I have this ad on a few forums. Please send me a PM if you are interested in any of these parts. I am located in Houston (77089). If you are inquiring to "shipped" prices, please include your zip code. Free bumps to the top are appreciated.
PayPal or cash in person only
“383”
  • Bare Block SOLD : Gen III LS1 aluminum, 3.905” bore, pistons come +0.010” out the hole. Machine work by HKE. Includes the main caps. For shipping request, please send me a PM with your full address.
  • Diamond pistons SOLD : Forged aluminum, 3.905” bore, 7cc dish, valve reliefs, for use with 6.125” rod. Includes wrist pins and rings.
  • OEM Ported and Polished Throttle Body $100 (shipped within the US): Just the TB no electronics. Photo1 Photo2
  • Jet Hot Headers SOLD : Just the headers and block off plates. You will need your own Y pipe. There is some minor surface rust, no dents, no dings, work great!
  • HPE “S-Cam” SOLD : 238/242/115/0.605" intake/0.610" exhaust on XER lobes.
  • Jesel Sportsman Shaft Rockers SOLD : Non-adjustable 1.7:1. Includes stands and mounting hardware. You will need taller valve, covers or valve cover spacers to use these rockers.
  • LS6 Intake Manifold SOLD : includes TB gasket and port gaskets.
  • SVO 42's (Green Top) SOLD : These flow ~53 LB/HR at the LS1 rail pressure. This will support up to ~525 rwhp at the stock 58psi rail pressure and 80% duty cycle. All o-rings have been lubed for storage/shipment.
  • Innovative LM-1 Wideband Controller SOLD: Includes WB controller, all cables, insruction manual, and factory box. Does not include the WB sensor - you will need to supply your own. The sensors can be bought from various vendors for about seventyfive dollars.
"L33"
  • Front and Rear Covers $50 (for both covers shipped within the US): Front and rear engine covers with gaskets. These will fit all GenIII engines. Photo1 Photo2
  • OEM Hydraulic Lifters $25 (shipped within the US): Includes 8 lifters, 4 trays, and all hardware. Photo on request. Look to be in good shape.
  • OEM Exhaust Manifolds $45 (shipped within the continental US): Includes the manifolds, heatshields, bolts, and gaskets. I believe these are the ones you want for custom turbo applications. Photo on request.
  • OEM Truck Intake Manifold: $75 (shipped within the continental US): Includes the intake manifold throttlebody gasket and port gaskets. Photo1 Photo2
  • OEM DBW Throttle Body: $75 (shipped within the US): 75mm Drive-By-Wire throttle body. Includes all electronics. Photo1 Photo2
  • OEM Fuel Injectors: $75 (shipped within the US): 8 Fuel injectors. I do not know the flow rating, but they came off a 5.3L truck. These are the "LS2" style injectors. Includes retaining clips and o-rings. Photo1
  • OEM Fuel Rail: $50 (shipped within the US): Fuel rail from the 5.3L truck motor. Includes the rails, cross over tube, and cross over tube hardware (three piece design). Appears to have significantly more capacity than the LS1-style rails. Photo1
  • OEM Crank Pulley: $25 (shipped within the US): This is the stock truck crank pulley. Photo on request.
  • OEM Gen3 Valley Cover: $65 (shipped within the US): Gen3 LS1 valley cover. Photo on request.
  • OEM Pistons/Rods SOLD - Rods 6”; Pistons 3.788"
  • OEM Crank SOLD : 3.622” stroke. Photo's on request.
  • OEM Water pump SOLD: Includes thermostat, thermostat housing, and gaskets. I have no idea if the pump actually works or not, the pully spins with minimal effort.
Old Aug 21, 2009 | 07:42 AM
89LS1RS's Avatar
any idea how much it would be to ship the crank and covers to 60076?
Old Aug 21, 2009 | 05:42 PM
89LS1RS - PM's shipped price
Old Aug 21, 2009 | 05:46 PM
transaman98's Avatar
pm me a price for the TB shipped to 66213!
Old Aug 21, 2009 | 05:57 PM
Haans249's Avatar
Great seller right here! I would certainly trust him! Good luck on the sale, all great prices!
Old Aug 21, 2009 | 06:05 PM
PM sent - let me know
Old Aug 21, 2009 | 06:58 PM
Did you have the TB on your vehicle? If so how did it perform? Any #'s to compare before/after port and polish?
Old Aug 21, 2009 | 07:22 PM
Worked great as far as I could tell. It was installed at the same time as a Volant intake and LS6 manifold so it's hard to narrow down the TB's specific contributions.
Old Aug 21, 2009 | 08:54 PM
sorry to bombard you with questions but is the hole that is in the TB blade factory or is it one that you drilled to help the car idle? Unfortunately I dont have my car around to go check.
Old Aug 21, 2009 | 09:22 PM
I don't mind the questions at all - helps to make sure you get the right part.
The hole is factory - no drilling. IMO, drilling is a bandaid for a bad tune.
Old Aug 22, 2009 | 04:24 PM
bump.
Old Aug 23, 2009 | 01:28 PM
Sunday Bump.
Old Aug 23, 2009 | 04:16 PM
rammor02's Avatar
What's the lift on that cam
Old Aug 23, 2009 | 04:32 PM
0.605" intake/ 0.610" exhuast. Added to the description
Old Aug 24, 2009 | 04:13 PM
Monday bump.
Old Aug 24, 2009 | 06:34 PM
BlackDemonSS's Avatar
Do you still have the LS6 intake manifold?
Old Aug 24, 2009 | 06:43 PM
It's still available. Boxed up and ready to ship. I'll PM you a price shipped to Riverside in a few minutes.
Old Aug 25, 2009 | 07:11 PM
Tuesday bump
Old Aug 26, 2009 | 06:27 PM
Wednesday bump.
Old Aug 26, 2009 | 10:03 PM
BLACKGOAT07's Avatar
Might be interested in Injectors.
